Yups, your BOV and comp cover / actuator annotations are correct in the second photo. That first one though? Need better picture, but looks like some scraggly looking boost lines. Cant be sure but looks the ones to the actuators? I have had em in years. U could try blowing through it.
Edited by GeeTR
https://www.sau.com.au/forums/topic/218226-whats-what/#findComment-3853263
I have a pic here of my engine that shows the vacuum lines...
The hose in your pic #1 goes from the vacuum pipe to the pipe thats joined to the o2 sensor harness bracket and then from there (where the blue termintor cap is) another hose should go to the rear turbo wastegate actuator.
Deren
Edited by Godzilla32
https://www.sau.com.au/forums/topic/218226-whats-what/#findComment-3855373
well in the first pic the blue vacuum hose is to the actulator. i found a pic anyways, looks like it goes to the return pipe of the stock BOVs i have blew in it and the air comes out of one of the vacuum hoses in my second pic, cant remember which one. i am trying to figure out what to use the the EBC
heres the pic
https://www.sau.com.au/forums/topic/218226-whats-what/#findComment-3856502
Ok sorry in the pic the blue hose looks like its just a blanking cap but its just the pic that makes it look like that. So anyway its going to where its supposed to go. Your right about the other hose, it is the turbocharger intake vacuum signal. It goes from the recirculation pipe y-piece and is normally connected to the top most pipe that runs behind the head. It comes out on the intake side of the engine and then is connected via a hose to the front port on the stock boost controll solinoid. So in other words just connect it to the port on your EBC that requires to be connected to the intake of the turbo.
Hope this helps :domokun:
Deren
https://www.sau.com.au/forums/topic/218226-whats-what/#findComment-3856565
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
