Hey guys,
Me, Mark (Marco-R34GTT), and Andrew (Fei-Sti Rex) are trying to remove Andrew's rear spoiler on his R34 GT-T. We have removed the 4 bolts, but cannot remove the last two clips that are holding the spoiler in place... We've tried everything to get these two clips out but we just can't do it..... It is just a stock couple rear spoiler... It is late, getting desperate, SOS!
Thanks..
https://www.sau.com.au/forums/topic/218235-remove-r34-spoiler/
I stand to be corrected, but when me and a couple of mates got together a few months ago to help remove the same wing from my friend's R34 GTT... after having done what you've done so far, we then had to unbolt 2-4 other bots holding the wing in place from within the boot itself from the inside.
What you'll have to do and I caution you that if you don't do this delicately, there will be a huge tear in the teal inside your boot which makes it ugly as... but yeah, you'll have to cut the sheet of metal from the inside of the boot and unscew the boot that way.
That's what we had to do, not sure if there are any other ways...
Good luck.
what do you use to cut the metal?
sh*t never knew a stock spoiler would bring so much misery and pain in trying to remove it!!!
yeah what do you use and umm.. your solution seems to be the only feasible one running through my mind at the moment...
cheers mate,
Andrew :thumbsup:
LOL dont cut anything you crazy mofos!
the last two clips (should be 3 holes in the boot, the centre ones are the big clip) are easy to remove. Get a mate to help (sounds like you have them :thumbsup:) and get a flat head screw driver.
Get the screw drivers head against one side of the clip, lever the screw driver so it pushes the side of the clip in and slowly lift the spoiler. This will cause the one side of the clip holding the spoiler in place to remain pushed against the hole in the boot, and therefore not clipping! Then be very careful, hold it in that position and place the screw driver on the other side of the clip. Lever, lift and hey presto the clip is out. repeat for the other side obviously. If your not careful when holding the spoiler with half the clip out, it will slip down and clip back in, making you start again.
Any more questions or explaining please ask, but dont cut anything is all i can say. Thats ridiculous.
Grant has the right idea, thats how i removed mine.
Takes abit of force depending on the double sided tape holding it down
good luck!
well i passed the pits just then, putting front bar and side skirts back on tonight as well as my new 18'' Enkei's...
wing is coming off TONIGHT! hehe
Grant mate great idea, looks like i'll be trying that tonight hahaha cheers guys, will keep you all updated
Andrew :D
  • 1 month later...
Hey so how did u go with this? I took mine off not too long ago...it just needed a bit of extra force to pull it off...(which, i admit, stupidly...was out of pure frustration haha) but luckily enough it was the right trick that was needed all along...
lol we ended up using a drill...
japanese double sided tape = worst b*tch ever...
have to weld up the holes now lol but yeah, looks way better without the GTT wing, GTT wing only looks good on cars like 300ZX etc.
my2c
Andrew
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
