For Those Who Like To Run Over Things
Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
Morning everybody, recently got a R33 Gtst Series 2, loving this site so far and getting some good info from here. Ideas for it is just get a new turbo/move it up with the engine, fix the transmission since second is a bit sassy when changing with some lovely metal shavings in the transmission oil and led conversion to make it look nicer. Any tips/ideas/info about anything is appreciated and happy to be here
That one is definitely wrong. Wastegate is connected to turbo inlet (via being connected to the BOV return pipe, which is connected to the turbo inlet). That is bad, bad, bad. You are driving that without a boost reference. It should be overboosting.
