ok, so i have a hks2535..
do i keep on adjusting my boost via the adjustable actuator (will annoy me after a while) - i know its better to keep the wategate shut for as long as possible yada yada
or
lower actuator to lowest + install the turbo tech i got sitting here
or
lower actuator to lowest + be a wanker and have a cool hi/low switch for daily driving then 'spirited' (as u sau gents call it) driving?
winter is approaching, dont think i need 18psi to do wat i do, rather keep it low and give the thing a easier workload for a bit.
i already have all the above parts next to me, i just started my apprenticeship so things like profec b are not an option right now as id rather make-do with the above suggestions...
any ideas?
Edited by DjeMz
  DjeMz said:
thats the thing, sick of feathering the throttle....
:thumbsup:
just dont mash it to the floor all the time.
I ran 24psi/350rwkw for ages, never really had a problem or needed to turn the boost down.
Even daily driving @ 270rwkw/17psi, 65-75% throttle = no problem easily.
Work with what you have...
Just use the turbotech to raise your boost to the desired level while using the adjustable actuator to control spiking or increase response...
I run the exact same setup with the same turbo on my rb20...works a treat...
