2008 International Engine Of The Year Awards
scathing
 Share
bribes and bum-licking
:ermm: Posts like this are why i joined SAU! bahahahaha
All due respect marlin you are talking through your hat. Having been privvy to some of the graft and corruption that goes on between motoring journo's and car makers It is safe to say that politics is clean compared to that crap.
Spot on. Political journalists are even worse. They're in bed with every politician and his wife.
I love the GTR to bits, but I am surprised the VR even even came in at third. The engine is not really a showcase for new tech at all. The direct injection 3.0TT BMW engine definitely deserved to win again this year, they are amazing. The torque they have off idle is insane for a 3.0L turbo engine, and yet they can be extremely economical, and require much less servicing.
Couldn't agree more. I would say the criteria for the prize would involve power, emissions, specific consumption/efficiency, mass and use of recycled materials, not in that order. Thats why diesels would do very well.
my cousin sold his gtr and bought one of those 135i bmw coupe things when he told me i was going to stab him then i drove it . . . . its f**king awesome i loved it. if i had the cash i would be doing the same but my budget will have me keeping to the gtr theme for a couple more years lol
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
