R35 Gtr At Gran Turismo
evovii
 Share
  • Replies 46
"Their detailer is a magician and worked on it for 3 days to get it looking like new again!"
Yes, that's Mario Corallo from Eurogloss Prestige. He specialised in Paintwork Corection (machine polishing) for all cars ranging from Toyota to Lambourghini. I have personally used his services many times, and his ability to 'restore' paint that appeared to be un-salvagable tp bringing it up to a high gloss professional finish is amazing. Price is very reasonable as well, and will look after any members if they mention that they are members of this forum. PH 0419 881 439.
only one place to take a car to get detailed in Melbourne, Damian @ Final Inspection
Do u get commission off this guy or what?
You put in so many shameless plugs its not funny....:P
i saw this beast on monday.
i went in to look at a evo 7 gsr they had there and it was at the back of the show room, its very sexy, they moved it out and back to the front and i could hear the beast purring, the guy reckons that nissan wont be bringing them to australia and that he reckons by the time he is able to comply his one it will be around 175k
btw i didnt end up getting the evo im probz going to buy the rx7 series 8 there (red) its nice as going back on monday to see it again.
and the r34 gtr nur in the pic sold to some 19 year old dude
cheers
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
