Hey guys, as some of you may know, not long ago I needed some help about driving my car untuned with a new turbo, injectors, afm and fuel pump, before I was going to get a tune.
I put in the turbo so far, getting a fuel pump this week and then put the rest in over the weekend or so....
but something a little strange seems to be happening to my car at the moment, with just the new turbo in...
The car is running brilliantly at the moment... even though its untuned I can tell there is alot more power... the only concern I have is that after I hit boost ( which comes on really fast and really quick - (2,600 - 3,000 ) and let off the accelerator and go into neutral... ie rolling to the red lights... the revs drop as normal...... but they go too low... they may drop bellow 400rpm or 100rpm and the car may even stall on itself... this only happens in neutral when revs are free... not when I am rolling to the lights in a gear after hitting boost and the revs are a much slower controlled drop.
These are my assumptions: (tell me if you have any other ideas what it could be)
1. Crappy tune- especially not for this turbo and the rest of the stuff I am going to put on (but we already knew this)
2. Standard Blow off valve not doing its job correctly any more because of bigger turbo (only running about 11psi though) and some of the air it lets back into the turbo and the other goes back the other way making the cho cho cho sound and goes out through the pod making the afm read negative numbers so it drops the rpm and retards timing,etc... so it almost stalls...
3. Timing belt/actuator i don't know??!? timing belt was changed about 40,000 kms ago....
so to help this I have heard I should relocate the afm meter to around the throttle body area and/or get a new BOV but I want something legal.... so maybe like a GTR one.... but I still don't know...
Thanks for the help in advance.
Adam.
Firstly why the hell are you boosting the car with A)A bigger turbo B)Standard fuel pump and injectors? :banana:
Your AFM will be the blame for the fluctuating revs due to the increased airflow,and going a bit crazy as its not tuned for it.
Gives a totally new meaning to fixing something that aint broke... She is broke because its untuned.
Get it tuned. Fix the problems after its tuned, if there are any!
lol... that was the first question I knew I was going to get .... just wanted to wait and see who was going to say it ! but to answer your question... it is very hard not to.... considering how quick the boost comes on... and how low it does.... I also forgot to mention I have a powerfc... but with a crappy tune.. I am not running on a stock ecu.... and thank you for confirming what I thought about the afm...but is it anything to do with the bov because it is making the woosh sound as well as the cho cho cho( so I thought some air is going around and some is coming back out the pod)
so if it is the afm... when I chuck in the z32 that I have... do I relocate it or will it do better once tuned in the same spot? I would like to keep it where it currently is...
Adam
You wont know it was running lean untill you blow it up. pull it appart and think... "maybe i should have waited to tune it before boosting it"
If your that short scrapped for cash PM me maybe i can do you a credit tune
Its simple dude,dont boost the car at all until you get the other mods done.Especially the tune.
But you will only be getting it tuned when you get all the other mods done.Reason being is the car wont run with bigger injectors,plus you will need to change the AFM settings on the PFC once the Z32 is wired in.
oh ok thanks for the info... and you can all rest assured and save lectures because I am not pushing the car... nothing over 3,000 rpm changes... driving like a pussy cat....
interesting guilt toy.. wot is a credit tune?
thanks
thanks
credit tune=tune now, pay later...
If you can hear flutter (cho cho cho sound) the air is bouncing out of the turbo back towards the AFM, AFM tells the ECU to add more fuel, ECU adds more fuel, not enough air, car stalls.
As stated above a tune *should* fix it. But i have no experience with hypergear turbos they may suffer compressor suge, either way see how you go.
ok, thats interesting... I don't know about the compression surge your talking about but yeh, I was hoping a tune would help the afm issue... I believe I am getting boost spikes as well..but I havent put my foot down enough to know for sure, but is that a symptom of the surge as well?
thanks,
Adam
Thanks Tao :D I have been really happy with it so far... just need to get a few little bits sorted...and the tune. oh and btw, I got my brakes sorted... used a brand of pads called qfc...I dunno much about them.. but they fixed the squeal! :thumbsup:
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
