I've lowered the Stag and I'm getting new mags and tyres fitted tomorrow.
I've opted to have the 4 wheel alignment.
The Stag is lowered, so will this be sorted out by the wheel aligner, or will something like this be required:
http://cgi.ebay.com.au/Nissan-200SX-S14-S1...1QQcmdZViewItem
Or is there another option?
https://www.sau.com.au/forums/topic/218342-probably-a-dumb-question/
Generally they run negative camber from factory. When you lower it, it gets worst.
Those arms are for extreme adjustment if needed. You may find if you need upto .75 deg of camber adjustment, 1 set of offset bushes from whiteline will be enough. If you need more upto 1.5 deg you can use 2 sets of bushes. Check sydneykids prices, around $100 a set plus fitting, need to press the old ones out etc.
You can get rose jointed upper arms, cheap ebay ones for $100 or jap ones for upto $400 which give you plenty of adjustment as well. I know sydneykid does not like the rose jointed arms for street use.
Get your wheels fitted, get a wheel alignment and what it ends up at. Then decide if you need to adjust it.
Check the suspension theads for sydneykid's recommendations. Running anymore than -1.5 neg camber wears the rear tyres pretty quickly.
i suggest an aftermarket arm
mainly cusco or JIC, or Kazama
all have decently quality endlinks, cuscos ave dust boots
i personalyl use dmax, but i replaced the endlinks with a better quality version
Thats my plan of attack for now. Just doing my homework, so if the wheel aligner calls and says there's too much -ve camber, I won't be surprised. LOL
I've lowered the rear enough you can still (just) run your fingers between the rubber and guard.
A pic would help ... I'd take one tomorrow during the day and post it up, but I'll have it at the wheel aignment joint by then :D
Pictures are useless, measure it, centre of wheel to guard. This is what is usually needed for each height increment:
Standard (new) height is 390 mm front and 380 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
