Hey guys, looking for some opinions!
Got an AE86 sprinter, currntly with a CA18DET conversion!
Now with the issue, the car has actually gone through 4 CA18's due to a number of things, but the last engine just blew up after being run a 7,000 rpm in 5th gear for a fairly long period of time! It burnt out the rod bushes on cylinder 4, basically screwing the bottom end!!
Just measuring up some options that we have now, which are to work the current CA18 giving it forged pistons, rods and a new crank rod, allong with boring out the oil wells to try and allow the oil to run to the bottom of the engine faster which we have been advised could have caused this issue! Also adding a larger and baffled oil sump! oh this engine is running a VL turbo pump with microtech computer and soarer FMIC running stock boost!
APPROX. $3500
The other option is to actually replace the current engine with a stock SR20DET and a small amount of boost! obviously having to change the engine mounts and exhaust pipe and using the standard computer! can get half cuts to do this for the usual $3000 to $4000!!!
What do you guys think would be a better option for reliability sake as this car does do track etc!! it runs great on stock CA18DET but the reliability doesn't seem to be any good!!
but heard that the SR20's have some generic faults as well!
which one would be a better option!
All sugestions would be great!
https://www.sau.com.au/forums/topic/21835-sr20det-vs-ca18det/
You thought of actually reducing the rev limiter down to a more reasonable 5000rpm and tuning the car more for peak power at around there, to reduce the stresses on the engine?? Just a thought...
Especially if you are doing heaps of drift work, peak power isn't everything.
With the SR20DET it also builds torque a fair bit lower down in the revs, so that would probably suit your application more it sounds. Don't forget the CA18 is pretty old now.. whereas the SR20DET still has pretty good support in terms of bolt-ons from Japan.
A proper rebuild on the CA will give you a fresh engine with forgies and rods for about 4000 or so if you remove the engine and take it to Roccos Performance. Theres a bokethere who loves CAs
An engine/gearbox swap to a SR from an S13 will cost you 4000 minimum (front cut) and it's still an unknown quantity. Plus you have to do the swap and engineer it and dick around fabricating new mounts and pipes so It'll blow out to 4500-5000 easy.
I'd go the CA rebuild unless you canget a SR engine that has a known historyon the cheap. It's easier and you will have a stronger engine at the end of it.
Just my opinion.
The CA will probably rev better for longer.
The sr wont like bouncing off the rev limiter or sitting at 7k rpm.
The valve train in the sr has been skimped on compared to the CA. Unless u switch the GTiR pulsar lifters etc.
Have a read of http//:members.iinet.net.au/~sayer/biscuits/
or search for silvia australia, and read the tech articles on the pro's an cons of both.
Originally posted by GaryD
the other thing to think of too is the sr20 is a fair bit lighter. could suit the 86 a bit better? but if i was in your position id rebuild the ca
Actually the engines weights are very similar.
Externally, The 2 engines look completely different, and they should. The first obvious difference is the SR’s shiny alloy block, Next you notice the different inlet manifolds. The list goes on. Don’t mistake that alloy bloke as being lightweight either – there is that much alloy in the thing to keep it strong that they weigh no less than the CA.
This was taken from Nissan Silvia SR vs CA
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
