Hey guys, looking for some opinions!
Got an AE86 sprinter, currntly with a CA18DET conversion!
Now with the issue, the car has actually gone through 4 CA18's due to a number of things, but the last engine just blew up after being run a 7,000 rpm in 5th gear for a fairly long period of time! It burnt out the rod bushes on cylinder 4, basically screwing the bottom end!!
Just measuring up some options that we have now, which are to work the current CA18 giving it forged pistons, rods and a new crank rod, allong with boring out the oil wells to try and allow the oil to run to the bottom of the engine faster which we have been advised could have caused this issue! Also adding a larger and baffled oil sump! oh this engine is running a VL turbo pump with microtech computer and soarer FMIC running stock boost!
APPROX. $3500
The other option is to actually replace the current engine with a stock SR20DET and a small amount of boost! obviously having to change the engine mounts and exhaust pipe and using the standard computer! can get half cuts to do this for the usual $3000 to $4000!!!
What do you guys think would be a better option for reliability sake as this car does do track etc!! it runs great on stock CA18DET but the reliability doesn't seem to be any good!!
but heard that the SR20's have some generic faults as well!
which one would be a better option!
All sugestions would be great!
https://www.sau.com.au/forums/topic/21835-sr20det-vs-ca18det/
You thought of actually reducing the rev limiter down to a more reasonable 5000rpm and tuning the car more for peak power at around there, to reduce the stresses on the engine?? Just a thought...
Especially if you are doing heaps of drift work, peak power isn't everything.
With the SR20DET it also builds torque a fair bit lower down in the revs, so that would probably suit your application more it sounds. Don't forget the CA18 is pretty old now.. whereas the SR20DET still has pretty good support in terms of bolt-ons from Japan.
A proper rebuild on the CA will give you a fresh engine with forgies and rods for about 4000 or so if you remove the engine and take it to Roccos Performance. Theres a bokethere who loves CAs
An engine/gearbox swap to a SR from an S13 will cost you 4000 minimum (front cut) and it's still an unknown quantity. Plus you have to do the swap and engineer it and dick around fabricating new mounts and pipes so It'll blow out to 4500-5000 easy.
I'd go the CA rebuild unless you canget a SR engine that has a known historyon the cheap. It's easier and you will have a stronger engine at the end of it.
Just my opinion.
The CA will probably rev better for longer.
The sr wont like bouncing off the rev limiter or sitting at 7k rpm.
The valve train in the sr has been skimped on compared to the CA. Unless u switch the GTiR pulsar lifters etc.
Have a read of http//:members.iinet.net.au/~sayer/biscuits/
or search for silvia australia, and read the tech articles on the pro's an cons of both.
Originally posted by GaryD
the other thing to think of too is the sr20 is a fair bit lighter. could suit the 86 a bit better? but if i was in your position id rebuild the ca
Actually the engines weights are very similar.
Externally, The 2 engines look completely different, and they should. The first obvious difference is the SR’s shiny alloy block, Next you notice the different inlet manifolds. The list goes on. Don’t mistake that alloy bloke as being lightweight either – there is that much alloy in the thing to keep it strong that they weigh no less than the CA.
This was taken from Nissan Silvia SR vs CA
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
