Hey guys, looking for some opinions!
Got an AE86 sprinter, currntly with a CA18DET conversion!
Now with the issue, the car has actually gone through 4 CA18's due to a number of things, but the last engine just blew up after being run a 7,000 rpm in 5th gear for a fairly long period of time! It burnt out the rod bushes on cylinder 4, basically screwing the bottom end!!
Just measuring up some options that we have now, which are to work the current CA18 giving it forged pistons, rods and a new crank rod, allong with boring out the oil wells to try and allow the oil to run to the bottom of the engine faster which we have been advised could have caused this issue! Also adding a larger and baffled oil sump! oh this engine is running a VL turbo pump with microtech computer and soarer FMIC running stock boost!
APPROX. $3500
The other option is to actually replace the current engine with a stock SR20DET and a small amount of boost! obviously having to change the engine mounts and exhaust pipe and using the standard computer! can get half cuts to do this for the usual $3000 to $4000!!!
What do you guys think would be a better option for reliability sake as this car does do track etc!! it runs great on stock CA18DET but the reliability doesn't seem to be any good!!
but heard that the SR20's have some generic faults as well!
which one would be a better option!
All sugestions would be great!
https://www.sau.com.au/forums/topic/21835-sr20det-vs-ca18det/
You thought of actually reducing the rev limiter down to a more reasonable 5000rpm and tuning the car more for peak power at around there, to reduce the stresses on the engine?? Just a thought...
Especially if you are doing heaps of drift work, peak power isn't everything.
With the SR20DET it also builds torque a fair bit lower down in the revs, so that would probably suit your application more it sounds. Don't forget the CA18 is pretty old now.. whereas the SR20DET still has pretty good support in terms of bolt-ons from Japan.
A proper rebuild on the CA will give you a fresh engine with forgies and rods for about 4000 or so if you remove the engine and take it to Roccos Performance. Theres a bokethere who loves CAs
An engine/gearbox swap to a SR from an S13 will cost you 4000 minimum (front cut) and it's still an unknown quantity. Plus you have to do the swap and engineer it and dick around fabricating new mounts and pipes so It'll blow out to 4500-5000 easy.
I'd go the CA rebuild unless you canget a SR engine that has a known historyon the cheap. It's easier and you will have a stronger engine at the end of it.
Just my opinion.
The CA will probably rev better for longer.
The sr wont like bouncing off the rev limiter or sitting at 7k rpm.
The valve train in the sr has been skimped on compared to the CA. Unless u switch the GTiR pulsar lifters etc.
Have a read of http//:members.iinet.net.au/~sayer/biscuits/
or search for silvia australia, and read the tech articles on the pro's an cons of both.
Originally posted by GaryD
the other thing to think of too is the sr20 is a fair bit lighter. could suit the 86 a bit better? but if i was in your position id rebuild the ca
Actually the engines weights are very similar.
Externally, The 2 engines look completely different, and they should. The first obvious difference is the SR’s shiny alloy block, Next you notice the different inlet manifolds. The list goes on. Don’t mistake that alloy bloke as being lightweight either – there is that much alloy in the thing to keep it strong that they weigh no less than the CA.
This was taken from Nissan Silvia SR vs CA
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
