Injection perfection (bankstown airport) seem to have a good rep. They quoted me $33 an injector, being cleaned in a bath, and then thru 1 of the pulsing machines. $33 seems abit steep?
Another place at lidcombe (search thru posts abotu cleaning) said $22 an injector.
Let me know how it goes. Im looking to do the same, though just waiting til i decide if im going to clean these, or replace with higher feed unit.
Thats like $190....???? I hope that includes flow testing and new o-rings etc. Ill try them on Monday.
Its strange the things that stick in your mind, i thought $8 (aprox) for ultrasonic cleaning was close to the mark, so maybe $33 is for flow testing and new o-rings etc?
I had mine done by Jamie Waterhouse (4721 7227) at peach tree... he did my whole 100,000km service (I supplyed the timing belt though) and I think it cost about $600 all up. Have the recipts somewhere but he has always met (or been VERY close to) his quotes and has also done a good job.
He once had my car for two days (Friday Arvo, Saturday and Sunday morning) looking for a problem with a miss... he eventually didn't find anything after spending most of the weekend on it (he usually only does half Saturday) and when he gave it back he said... I could not find the problem... (Pressure tested and flow tested and all sorts of things... even had the fuel pump out) when asked how much I owed him for his time he said "nothing... he didn't fix a thing."
I noticed that I got a much more smooth power delivery and it felt to me like I got a power gain. I had the injectors removed when they were cleaned.
I have also heard good reports about Nepean EFI and they are just off Batt street I think?
Yeah , I see your point Ben.
Flow and pattern testing , as I understand it means: Pressurize each injector, activate it, measure the flow (in cc's) and pattern (like does it dribble or is a nice spray) [yeak OK that is not a very technical explanation]
Cleaning is seperate -
No point cleaning a stuffed injector !
It included new O-rings and Plastic tips (whatever they are called) and were ultrasonically cleaned, and flow tested as well as checking the spray pattern.
Let me check the receipt when i get home for the name, i only know it as the blue building near the gym
As for differences in driving, ill never know, they are GTR injectors going into my Rb20, along with a new turbo and ECU. So was more a peace of mind thing for the new setup
Roy,
Did you get the results for each test on each injector - like on paper ?? Or did they just say 'yeah they are ok'
If the former, can you let me know where you got them done ??
I need to test 6 Hi Flow pieces of shit injectors - prolly they are still stock which would explain my smallish engine issue.... Anyway that's another story....
Thanks mate,
