Ok name is Norman Andrews Automotive Repairs, in Richmond. Ph. 4588 5777
Receipt reads: Check injector, fuel flow and spray patterns, ultrasonic clean injectors, replace pintle caps and seals as required.
I also got a sheet listing before and after flow, spray pattren and leakage.
The after results list spray pattern as good, leakage Nil and flow improved and equal across all injectors (contrived, typical i dont know, it could have to do wiht the method of test????)
Reason i went there is i have often seen imports there (he brings them in occassionally) and runs a well presented/ neat workshop.
Apart from the injectors all having the same after flow value, is that normal, i would assume a little variance is typical, im happy.
Did you get like some kinda dyno type printout of a before/after of the flow etc ?
Be interesting to see the difference.
Hand written .
BEFORE
Injector Fow Test Spray Pattern Leakage
1 100 Fair Nil
2 100 Fair Nil
3 102 Fair Nil
4 097 Fair Nil
5 098 Fair Nil
6 098 Fair Nil
AFTER
1 110 Good Nil
2 110 Good Nil
3 110 Good Nil
4 110 Good Nil
5 110 Good Nil
6 110 Good Nil
Does the fact that they all had the same flow after the cleaning seem a little rehearsed??????????????
Still at the very minimum they have been cleaned and are all working properly so wont cause my engine to let go when installed.
Originally posted by B-Man
I thought flow would be in cc/per sec/minute/hour or whatever.
Same ere, still though u got atleast a 10% better performing Injector after having them cleaned so it should be good.
How much would it cost to clean carbies, i got a civic twin carb.. im stuck with it till i get cash for a skyline, suppose some extra grunt wouldnt hurt, getting extractors put in for $150 air filter isnt possible on my 1 i dont think :(
i got some fuel cleaner too, some red shit u put in petrol
92model civic hatch
