Hey guys Im looking at buying a clean, Non turbo R33. Has to be manual. If you are currently or thinking about selling yours reply back with details and pictures or just pm me
Cheers!
Ooo talk about demand.. So many posts from people wanting to buy..
https://www.sau.com.au/forums/topic/218363-wtb-r33-gts/#findComment-3852271
Someone isnt going to be happy about this *jumps into flame proof jacket*
who???
it's just a prime time to sell... the NAs are fetching for more than the GTSt now.
i'm almost tempted to take the plunge and go for something like the V35.
a full race ready GTS perfect for the P plater to upgrade to a sweet motor when they come off their Ps
https://www.sau.com.au/forums/topic/218363-wtb-r33-gts/#findComment-3852903
only prblem is that many people can't spot whaht good mods are.. especially for an NA.. too many people are focused on the turbo craze..
If only they knew the NA feelings of a screaming motor!..
SEX!
Underpowered = awesome fun!
/end drunken rant after uni bar.. Regrets tomorow mmorin? You bet!
Edited by GTS4WD
https://www.sau.com.au/forums/topic/218363-wtb-r33-gts/#findComment-3853211
LOL... i wouldn't entirely agree that being underpowered is fun.
a high compression, individual throttle bodied motor with a 9000+ rpm redline however!!! enough to send shivers down anyone's spine Inline 6, V6 or V8 (and in my dreams V10)
https://www.sau.com.au/forums/topic/218363-wtb-r33-gts/#findComment-3853442
Eug I've just seen your GTR seats... I'm a very jealous man.. yeah well if I struggle to sell the car - you'll be the first man i'll speak too.
but at this stage we'll see what interest comes around the corner in regards to the car as a complete package.
https://www.sau.com.au/forums/topic/218363-wtb-r33-gts/#findComment-3861852
  • 1 year later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
