My gearbox has a loud clicking noise when it's changing from 1st to 2nd (under acceleration)
and from 3rd to od (when pulling off throttle) and going into reverse.
Cant hear it in the car only when the window is down
Don't know if it's serious because its still changing gears freely
keen to find out what it is so i can nip it in the bud
https://www.sau.com.au/forums/topic/218399-gearbox-click/
  • 4 weeks later...
Ended up being a loose cv joint in the rear right (when jolted, would click)
not the gearbox after all :)
got it fixed for free during a gear box service
got a transfer case refill as well (0.5L!!) with no clear leak :D
https://www.sau.com.au/forums/topic/218399-gearbox-click/#findComment-3926740
Ahhhh ok. Mine has been doing this for ages and I just stopped taking notice as nothing seemed to be affected. I had a feeling it might have been a rear C.V or something as the noise only have from the rear. Mind you it only does it when I'm reversing or just taking off in 1st under light throttle and then thats it, don't hear it again. Seems like a pretty easy fix then
https://www.sau.com.au/forums/topic/218399-gearbox-click/#findComment-3928354
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
