Brake Specialist
WYTSKY
 Share
Hey guys, just wanted to know if anyone could recommend some good brake specialists around the metro VIC area... I am in the SE suburbs but would probably drive up to Darwin to get my brakes to stop squealing so bad! A cop almost wanted to defect me for them today! load of Cr*p! SOOO I promised him I would see a brake specialist as soon as possible... so I am being a good boy!
Thaanks!
Adam
racebrakes are in north melbourne, 2 seconds from the city
they should be able to help you out
the squeak is from the compound of the pads you are using
try different pads, bed them in, fry em and away you go
thanks bud, any others you can think of?
and I have done soooo many things.....
some new crappy feddro pads.....nothing... changed to bendix general under some advice that ultimates are too firm.... did nothing... machined the rotors... did nothing... changed to ultimates... nothing... anti squeel stuff.... nothing... shimmed... nothing... sanded pads back to a bit more rough... lasted 5 mins... I am sick of it!!!!
lots of disapointment!!!
are you using all the shims behind the pads?
i also used racebrakes, they've moved to yarraville now.
Thanks for the help guys, I ended up going to brakes plus in Burwood today, they were very handy and installed some premium QFC pads in the car for 140 bucks including labour...and so far so good :ermm: no squeaks... Im bloody happy....for now :D
you changed to ultimates to try and get rid of squeal?
ultimates a renound for brake squeal!
mmmm... found that out after about using them for 100km and 120 bucks!!
Try Lucas brake pads better than ultimates can take like 600 + degrees and does not squeel and good on your rotors, i use them on my skyline silent as no problems, only down side is allot of brake dust but i dont care about brake dust only squeeling matters for me and i clean my mags when i clean car so who cares, also you should try the maintenance part of the forum under brakes and suspension and search it up lots of threads about it buddy
http://www.skylinesaustralia.com/forums/Br...gs-t169972.html read this thread all about brake pads and if they squeel i payed like 100 + for my pads i spend more to get good quality dont use cheap ferodos
 Share
