I have a client that I'm looking to setup 5-6 Cisco 1841 Routers for and I'd like to have the fitted WIC's failover but it's not something I have experience with. I was hoping someone here might be good with Cisco IOS as I'm only self taught.
What I'm looking to do is install an 1841 with two WIC's, 1 ADSL and one SHDSL and if interface 1 go's down it will fail over to interface 2. I have experience with setting up the interfaces to work independently but there is some tricky routing involved with failing over and I'm a bit out of my depth.
Has anyone done this that can help? I'm happy to pay. Cheers :down:
PS - If you don't understand what I've just said don't fill my thread with garbage :wave:
https://www.sau.com.au/forums/topic/218439-cisco-help-required-1841-programing/
I understand what your trying to arrange. Its been a few years since i studied the CCNA so I would only be looking through a manual myself.
Now youve got me thinking constantly about how to do this >.<
Yeah it's a bit of a tricky one for me too. It's just a job I'm outsourcing not a full time position but it would be good to have a relationship with someone with a strong Cisco knowledge that we could call on for work as we sometimes have drama’s with VPN and Crypto too. If you think you can do this sort of stuff we can talk $ :wave:
hsrp attached to the wan interface will do it
both routers run hsrp between each other and send echo packets
they also share a virtual ip between them
if one of them doesn't respond to the echo within set timeout the other router takes over the virtual ip
there's always a master and a slave in the hsrp
ive got a book / pdf if you want to do it yourself, its easy
ah i didnt see it was on one device, well yeah just set to two gateways with different metric
the lower metric being the primary route, and the secondary with the higher metric
i assumed you had two routers
yeah if you have two routers, then HSRP is spot on
will give you want you need, just make sure you set it to watch the serial or dialer/0 interface for the dsl connection
and test it of course, also make sure to set the priority, dont assume defaults
for those interested in similar topics check out;
network warrior
http://www.amazon.com/Network-Warrior-Gary...7458&sr=8-1
a recommended read
it covers advanced and commonly used scenarios of networking and networking concepts
the pdf version is on bit torrent if you want a sneek peek, but the paper back is recommended
http://www.mininova.org/tor/860447
i purchased mine from amazon.com delivered in about 1.5 weeks for $49 new
adz,
get cisco's packet tracer.
setup your routers in it, test it all out..configurations/layouts/etc and use the book resources to help you if needed!
router simulation easiest way to go about it
let me know if you want a copy
what if the interface stays up but theres no ip connectivity, twill never swap over :thumbsup:
best way is to setup object tracking/EEM applet on the cisco so it automaticaly pings the default gateway every few seconds then if it fails it swaps over by itsself.
justin911 makes a good point - and the main point why traditional interface down detection methods won't work with ADSL.
The ADSL line sync (layer2 of the OSI model) will be the main interface that the detection will work on. What you'll find is that most of the time, the PPP layer (layer 3 of the OSI model) will be the one failing, and you'll lose your PPP link - which means no traffic. This PPP fail won't trigger the interface as being down.
The default gateway idea is the most logical however not always reliable. I suspect that depending on the routing protocol it might not always detect the ADSL/SHDSL fail and keep pumping out packets to the default gateway with the lowest metric which will result in lost packets and no connectivity.
Not having any live cisco equipment I can't say for sure (and I don't work on the equipment on a daily basis anymore) but being a good cisco tech I did some googling and found the following:
http://wiki.ittoolbox.com/index.php/Cisco_Failover
This is an IOS feature (sla monitor/rtr?) that tests a particular IP address for certain criteria, ie:
IP sla monitor 1
type echo protocol ipIcmpEcho your_first_test_ip source-ipaddr your_source_ip
timeout 2000
threshold 2000
frequency 3
IP sla monitor schedule 1 life forever start-time now
Basically the above will ping a particular IP through a particular interface and make sure it meets the SLA of 'a timeout of no longer than 2000ms' and 'no more than 3 failures in a row' or something to that effect.
Look at the website above and the rest of the commands will set up the routes etc. Its a start but I don't know how useful it is - and you're right, it's probably out of your depth - heck its even out of mine and I'm a CCNA/CCDA/VOIP etc.
Like i said mate i'm not working on the stuff full time anymore but I can still get my head around most of the stuff. You'll be able to find my ph number. Gimmie a call anytime - don't feel afraid to chuck me a config file either :)
More info for you here Adz:
http://www.velocityreviews.com/forums/t552...cisco-2801.html
And as Justin mentioned above, object tracking sounds like what I found above, however i havn't worked on it before:
http://www.cisco.com/en/US/docs/ios/12_3/1...e/dbackupx.html
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
