We've just been able to scoop purchase Oakley Racing Boots at a ridiculous price!
All of these boots RRP for over $400, and we're selling them off on special for $249 shipped!
In Compliance with FIA Standard 8856-2000, these boots are suitable for use in all motorsport events right up to Formula 1 and World Rally!
The sizes are US, so they're 1 above the UK system, which is what we use, so if you're usually a 10, then you'd need to choose 11. For those that are local (North Brisbane) best to come in and try them!
Or else the Oakley Size chart is here:
http://oakley.com.au/customer_service/footwear_chart
They use the US system, so that's the available sizes we've quoted here.
Black High Race Boot
Photo 1
Photo 2
Available:
1 x Size 7
2 x Size 11
1 x Size 12
Red/Black High Race Boot
Photo 1
Photo 2
Available:
1 x Size 8
2 x Size 9
1 x Size 10
2 x Size 11
Red/Black Low Race Boot
Photo 1
Photo 2
Available:
1 x Size 8
2 x Size 12
1 x Size 13
Blue/Grey High Race Boot
Photo 1
Photo 2
Available:
1 x Size 7
1 x Size 12
2 x Size 13
All brand new, in box, with Oakley Warranty. Any other questions PM us here, or call (07) 3881 1215.
Regards,
Greg
Also just had it confirmed by the ANDRA rule book that these are also good for everything up to and including Top Fuel.
These will cover everything from weekend sprint warrior, right through to international competition!
Updated Availability...
Available:
1 x Size 7
3 x Size 11
Available:
2 x Size 9
1 x Size 10
1 x Size 11
Available:
1 x Size 8
2 x Size 12
Available:
1 x Size 7
1 x Size 13*
* Sold, but may still be available... I'm supposed to be taking it to an event in a month's time, but if someone walks through the door with cash in the meantime...
definately keen on some boots man
how generous are they with there sizing.. ive had a few race boots now .. same sizes .. one was rather loose.. the next was same size but slightly better fitting.
im intersted in a pair of Black High Race Boots.
reason i ask in regards to sizes .. im a US12 .. but isnt really tight on the end of my foot. i could go an 11.. and maybe stretch where it needs?
keen all the same.
and if u can get gloves that would be awesome too.
Matt
Hi guys,
For the both of you, unfortunately no-go on the gloves.
They'll stretch a little. I kept a pair for myself and wore them around work all day on Tues to get them to loosen up a bit. Really depends on how wide your foot is I guess. If you're not quite as long as a 12, then maybe you could get away with the 11.
Worst case, the $249 includes shipping to you, so provided you're prepared to pay any return freight, then refunding you your money isn't an issue.
Also, there's only 1 Size 11 black left. Updated availability is:
Available:
1 x Size 7
1 x Size 11
Available:
1 x Size 9
1 x Size 10
1 x Size 11
Available:
1 x Size 8
2 x Size 12
Available:
1 x Size 7
Regards,
Greg
Only a few sets left! Updated Availability...
Available:
1 x Size 7
Available:
1 x Size 9
1 x Size 10
1 x Size 11
Available:
1 x Size 8
2 x Size 12
Available:
1 x Size 7
Yep, we've still got:
Available:
1 x Size 7
Available:
1 x Size 9
1 x Size 11
Available:
1 x Size 8
2 x Size 12
Available:
1 x Size 7
  • 3 weeks later...
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
