when the car cuts out, i try to rev but nothing happens. feels like a mad misfire, does this sound like the problem of the ignitor module?
car would then die.
wont be able to start until a few minutes later, it would stay alive without having to give it gas.
Edited by whyte
car would then die.
Sounds like it.
If you get some freeze spray from an electronics store, spray very liberally over when the car dies to cool the box right down
And it should start up right away.
Its usually heat that gets them, so the ole freeze spray is a good test that ive done in the past
im checking them tomorrow ...
if they seem fine im just gonna drop it off at the mechanics and let them decide..
problem is that it only happens intermittently
after i replaced the ignitor, it was fine all day until around 8pm tonight it started playing up again.
if i check the coils im pretty sure it will seem fine until it actually starts to cut out.
Edited by whyte
Did you take a close look at the coil packs for hairline cracks?
This may not even be a ignition problem. Hard to say without witnessing the problem first hand. Intermittant faults are tough to diagnose so good luck with it mate :blush:
