hey my RB20DET has been making a tapping noise recently heres some facts
-always there hot or cold
-quicker with reving
-is silent when off the accelerator
-sometimes i get an ECU error on my consult screen (34) knock sensor :) usually only for the first 5 mins on very cold mornings but sometimes during normal conditions....
-i wired the fuel pump straight to the battery so its on full blast all the time, there was not much noise before this if any...
-revs are a bit strange sometimes at idle it will just go up and down between 1k-2k rpm sometimes will go down to 400rpm when stoping
-if i give it some just after it starts i will get a screeching noise for a few seconds sounds like fan belt but its a little different
-its not that loud if you rev at idle, heaps louder under load
-misses randomly sometimes
-i can't be sure but sometimes it feels like the engine is being held back, like the handbrake is being pulled... not sure about this though
basically trouble started after fuel pump relay died and i wired it straight to the battery this may not having anything to do with it, cause i was also doing some very hard thrashing at the time....
i have listened to it at idle with a screwdriver but i can only hear the fuel rail and injectors ticking which is normal i guess.
i was thinking that the increase in fuel pressure could be making them noisy but not sure...
could be lifters i guess but the sound should be there on and off the throttle which it is not?
any ideas?
https://www.sau.com.au/forums/topic/218497-tapping-noise/
Look it could be injectors and 2-3 other problems... as some of the things you've put down are not solely one thing or another
Like the miss, motor feeling like it held back etc.
My motor even with 2 blown piston rings still went alright if i made it, it was just a bit smokey.
But then it could be worst case as Jono said, and thats fairly likely.
Also - dont hard wire the fuel pump. Its dangerous.
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3855186
whats it cost to replace a big end bearing with and without labour?
i think it might be better to drop a second hand one in with decent compression, cause last time i checked 40000ks ago it was around 110psi so fairly worn.....
apart from being dangerous in a crash situation why else is it bad to hard wire the pump?
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3855360
sounds like a big end bearing to me too. if it is worse with revs and when cold.
don't run the motor, get it towed and checked out. if it is a spun bearing it can get much more expensive very quickly.....
btw ash not sure why you think direct wiring the fuel pump is a bad idea, we do it all the time. the standard fuel computer often causes serious problems
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3855416
wait till you have an accident the the car keeps pumping fuel while its upside down
catches fire
doesnt end nicely
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3855435
if you catch it really early, you can get away with just slapping in a set off bearings. We did it to a mates car, 30,000km on and its still strong.
If you've done a bit of damage to the crank you may have to get it machined, so pretty much a full rebuild will get done if the motors tired.
or like you said just buy a 2nd hand motor, probably the cheapest option, but you may be buying someone elses problems
OR
slap a rb30 bottom end on your head :thumbsup:
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3855745
if it was a big end bearing, wouldnt u still hear the tapping when ur off the accelerator (ie decelerating) ?
i would have thought there would be a constant tapping, either accelerating or decelerating?
when u start it cold, have a light sniff around the exhaust manifold/turbo area, if it smells of fuel, i think its the exhaust manifold gasket.
for me it explains most things, but doesnt explain the idle.
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3856607
if you can stop the cylinder firing one at a time from 1 - 6 (you can do this by disconnecting the injector, coil or lead of the cylinder) you will be able to find out if it is actually a big end noise and exactly what cylinder its occuring. when the cylinder has no combustion most times if its a big end the noise will go away.
Hope this helps.
Cheers Matt.
Catch it early and you may get away cheaply.
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3856751
yeh i have one nut left on the manifold its a bitch im gonna have to take the rocker cover off to get to it....
the previous owner put one of those Chinese stainless manifolds on, its cracked where the pipes come together complete junk.
im gonna source a standard one and put that on.
thanks for all the help guys :domokun:
https://www.sau.com.au/forums/topic/218497-tapping-noise/#findComment-3856813
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
