Yeah the silver 33gtr was my car. 1st pass was just feeling out the new tyres dropped it at 7ish and it just bogged real bad. 2nd pass i thought id try 8000 and it just wheel spun/ tramped hard. Ran a slow 1.99 60ft on the 10.9 pass was doing 106mph in 1/8 going by giant and dirtgarage time slips it should be good for mid 10's or quicker.. On PITS 4wd dyno yesterday made 550awhp pump 24psi and 630awhp 26psi on vp109. Doing alright on 2530's running standard ignition system/splitfires plugs gapped to .8mm...
was a good and quiet night :D
some pics..
Lil bro, your 31 is even in the background of the first photo. Well at least the front half of it is... Should get Heath to take his 31 down the track.
Congrats on the time Baz!
Internally standard engine
gt30r turbo
555cc injectors
Custom front facing plenum with Xf throttle body
Custom exhaust manifold
Custom made dump to cat
walbro fuel pump
AVCR
FMIC
45mm turbosmart wastegate
turbosmart bov
3" exhaust
Front and rear strut braces
I think thats about it, apart from heavy duty clutch and kyb suspension.
Im building a new engine currently so will be keen to try that when its finished
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
