Alright guys, in the process of buying some go fast bits for my GTR and just have a question. I'm looking at getting some GT2860-5 turbos and thought while I'm at it, why not upgrade the standard manifolds to something like the Tomei Expreme items. Only problem is, is the roughly 1k for the manifolds a waste of money? Are there any real noticeable performance gains or should I be looking to spend that money else where?
The car has a PFC, 600CC injectors, clutch, AFM's and fuel pump all ready to go in just looking at the last few pieces... Any help here would be appreciated...
Cheers :)
https://www.sau.com.au/forums/topic/218511-upgrading-manifolds-on-gtr/
I've been told not to bother by Racepace, and none of the other cars running those turbos are using manifolds either.
For bigger turbos i believe yes (like GT-RS) but for -7, -5, go with factory for the cost.
The Tomei dumps are nice though, i've got a set going on at present.
the beauty of the stock manifolds is their ability to retain gas path heat due to their cast thick wall construction. If manifolds are upgraded is is necessary to perform some form of heat retention i.e. Ceramic coating or thermal wrapping.
if its a street car...retain the stockers...if you want gains you may opt to extrude hone them to improve flow.
Was considering a set of these for my semi-track car, still street driven. have alreadt got the trust dumps wih ceramic coating and had planned to coat these manifolds and exhaust housings on my turbos HKS2530's mostly to try to reduce underbonnet heat though it sounds like this may resolve the problem you mention also. And having them match ported.
Just curious if anyone thinks these offer any real gains over the same treatment to the stockys
Edited by noone
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
