my r32 gtst rb20det doesn't start properly, it is very hard starting it and wen it does start it's like it's missing badly but if u keep pumping it eventually piks up but u still need to hold the pedal down otherwise if u let go it dies. wen it warms up u can let go and it'll be ok, restarting isnt as hard....only cold starts is a problem
i have tried:
replacing plugs with iridiums 0.8mmgap
testing my air flow meter on another r32
swapping the ignitor
swappin the silver thing on passenger side strut tower...wat is it?
swapping the oxygen sensor
cleaning the aac valve
cheking the tps
cheking for vacuum leaks
bypassing fuel pump relay
chek fuses etc.
it's like something isnt letting it idle and start properly initially but wen it warms up it gets better.
if it makes a difference then the exhaust smells very rich and blows greyish smoke wen engined is revved
tried search function but got no answers....any ideas/experiences will be a great help !!
jay
https://www.sau.com.au/forums/topic/21855-pleeeze-help/
All i can think of is the Computer may have had it...I was gonna prob say faulty fuel pump or injectors but If u say its running fine when it warms up Then not Fuel...
Best thing you could do is go and get it Checked out :D
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-464263
i thought of the computer aswell but i don't understand why it runs normal when warmed up. it's almost like a sensor or something has a intermitent problem.....and doesn't like doing it's job when cold. anybody know what keeps the rb20 idling, does it have a idle controller or something...
thanx for the replies, keep the ideas rolling in, might help me stumble on something obvious !!!
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-464492
i have a similar problem:
sometimes starts first go sometimes not (used to NEVER start first go). cranks fine.
when it does catch on, it revs really low for a couple of seconds - like its trying to rev up but can't. in 5 seconds it magically goes up to 1000rpm and idles normal.
dunno what it is. does this sound like spark plugs? tried cleaning AFM, played with TPS, ran some injector cleaner recentl.
i htought this was a similar topic so someone might be able to help me too...
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-466578
wazr32 - thats similar to wat i have but alot worse, it just doesn't tip start and hold steady like it shud.
r34gtt-r - when u say thermostat, do u mean wat was said earlier about the sensor or the actual thermostat that opens and closes the water flowing in the engine from the radiator.
jus remebered that tucked away in the glove box is a hks idling stabiliser...don't kno y this is for (beside the obvious in its name)
tested it plugged in or out, doesn't make a difference.
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-466962
Mine does it as well but not as bad....i just need to give it a lil rev sometimes to get the revs to pickup to over 1000rpm
My bros car does the same thing.
Scott
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-467114
yeah is i give the accelerator a poke it goes up to normal its only if i let is run will it struggle for revs then come up to normal in a few seconds. its perfect when i start it when its warm.
thermostat - good idea. has to be temperature-related i rekon. although i don't see how the coolant circuit relates to the starting characteristics...
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-467136
checked on my rb20, the top coolant pipe has 2 sensors plugged in, one is a single wire clip the other is a 2 wire clip. the single wire is for the temp gauge, when pulled out the temp drops to nothing. the other 2 wire clip does nothing when pulled out ???? maybe this is the info the computer reads ????
2moro i will unbolt both the sensors and have a visual inspection inside.
chow for now :-)
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-467253
Mine does the same thing too ever since I got it. However mine did get much better after it had 2 exhaust valves replaced (i think that cylinder was down on comp for a while which wouldnt have helped cold starts). But it still coughs and splutters about in the morning.
Im told its due to my Blitz ECU. Im told alot of jap ecu's have cold start features removed and thus run a bit crappy until the engine is warm.
Red17
https://www.sau.com.au/forums/topic/21855-pleeeze-help/#findComment-487902
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
