hey guys, just wondering, seen heaps of custom cooler piping, mostly on jap cars, that seems to have a weld not running around the pipe, but sort of along it on the bends. as i understand it mandrel bending with a machine isnt real common practice in japan, so they do it in other ways, is this something to do with it?
*as luck would have it i cant find many pics, something like this though:
2262532826_e6d346d6e1_o.jpg see the seam running along the radius?
Donuts are two pressed (or spun) halfs that have to be welded together into a full ring, before you cut them at the angle you need. Aluminium is a soft metal that crushes easily unless it is handled correctly when bending.
Cheers, Greg.
half donuts are spun - allows pipe out of flat sheet alloy, and the possibility of 180 degrees in different radius - cheapest option as for $25 ish you get 4 x 90 bends
Where do you get them for that price? Last time i checked JNT were a bit more (about $25 per half)
i get it at trade through a mates sheetmetal place - but it does depend on the diameter piping you need - JNT have 4" for $25 per half
hardest thing to get these days i've found is thin wall 3" straight lengths - took 3 weeks to get a length in
You buy donuts because you get a tighter raduis than any bends you can get, and to get any angle cut you like they are awsome for making radiators and the like try them out If your in Melbourne pm me and I'll hook you up with some
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
