joeyjoejoejuniorshabadoo Posted May 12, 2008 Share Posted May 12, 2008 what difference do you get with the heat ranges? i run BCPR7ES @ .6 and am due for some freshies... will it affect anything changing to say a 6? Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3859199 Share on other sites More sharing options...
RBwhatever Posted May 12, 2008 Share Posted May 12, 2008 RB25, Iridiums, 1.1mm, 200rwkw??, 12psi, heat range 5. Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3861456 Share on other sites More sharing options...
limpus Posted May 12, 2008 Share Posted May 12, 2008 I run NGK BCPR6E in my car...same as the BCPR6ES except that it has a V groove in it...rb20det...19psi...237rwkw... Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3861483 Share on other sites More sharing options...
nuclear_skyline Posted May 13, 2008 Share Posted May 13, 2008 My understanding of heat ranges with cars is that colder running plugs cope with higher temps and more grief then hotter plugs. The down side is that if you go too cold with the plug they can foul easily at idle, on the HWY, etc... Colder plugs are better for reving, hot engines??? (I am so going to get crucified for that). I know that when I put my cooper s on the track, I change the plugs down to a colder set and that gives me a more consistent and reliable spark then normal street plugs... But if I try and drive around the street on them they foul in 10 mins... Not sure what range would be too far for you Hamish... Sorry Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3861980 Share on other sites More sharing options...
blind_elk Posted May 13, 2008 Share Posted May 13, 2008 ive tryed iridiums and they foul up when the car breaks loseusing copers and they fowl up when i give it stick when its cold just looking to see what people are doing It runs RICH when the engine is cold. You shouldn't be giving it stick when the engine is cold.Some people don't deserve a Skyline. Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3862289 Share on other sites More sharing options...
RB120WHY Posted May 13, 2008 Share Posted May 13, 2008 ive been suggested to run ngk r5671A-8 like 6bucks a plug and they reckon they do the job The chosen plug of champions. I have used these plugs in my RB20 and now have a set in my RB30/26 Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3862780 Share on other sites More sharing options...
neo32 Posted May 13, 2008 Author Share Posted May 13, 2008 It runs RICH when the engine is cold. You shouldn't be giving it stick when the engine is cold.Some people don't deserve a Skyline. i take offence to this wen shit i mean 4k in the first 5 mins Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3863022 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted May 13, 2008 Share Posted May 13, 2008 you cant take offence... you said: "when i give it stick when its cold" Link to comment https://www.sau.com.au/forums/topic/218605-spark-plugs/page/2/#findComment-3863109 Share on other sites More sharing options...
