  • Replies 71
i agree. na vs na should be a good battle. but adddin forced fed induction is a whole different ballpark.
my mate imported a na 200sx from japen. i'd LUV to drag him but he wont go me. hes just got a new engine but....maybe he'll go now. btw hes got a $3000 boot setup so im thinkin its over alreadi.
ur not very bright are u...
Did u think about the torque band a turbo gives u??
Also ca18dets dyno at around 5-10kw less at wheels.. so they aint that much slower if the engine is still in good nick.
Aint NO WAY a rb25de will beat a ca18det, its turbo against n/a dude seriously wake up..
Just because its turbo doesn't magically mean that it is a faster car.
The RB25DE has 700cc more displacement, 20kw more power, 5nm more torque, and the sky doesn't weigh THAT much more than the sil. Therefore it has the potential to beat the CA18DET silvia. The linear power delivery from the RB25DE also gives it an advantage.
remind me who wasn't very bright and needs to wake up?
Stock for stock I'd place a bet that they're fairly even.
ps. i thought about the torque band a turbo would give you as you suggested, and then decided that it was crap.
Thats why a rb25de runs 16s n a ca18det Sil runs 15 flat
Its about power delivery my friend, the DET will bring on torque at 3,500rpm ALOT more than an n/a wud have at the same rpm figure.. ie makes it easier to get to its max power quicker.
A Skyline weight is around 200kgs more than an s13.. thats alot dude.
Stock for stock its not much of a match. 0-100 times and 1/4 times prove that.
Doesnt really matter if u agree or not.. go race a ca18det and find out. I understand u have a GTS therefore are abit bias which is fine too dude :D
Just dont expect to much out of an n/a r33. Theres a reason they run 16s..
fair enough, you have a pretty solid argument. i'm going to race a ca18det silvia and report back
and yes i am biased so i will defend my motor: as i said, it has linear delivery, power doesn't suddenly kick in at certain revs. theoretically this should allow a better launch. anyway they're both great cars and i know which i'd prefer for a drift car (sil obviously)
well, I didnt buy R33 GTS-4 for Drags. I looked all the NA cars and skylines had most option and value for money..... beside I like all the imports.
No point arguing for nothing. they are all slow compare to Turbs but no way they get same milage on the fuel.
so lets just calm down girls.
my two cents. :D
thats pretty obvious.. put a Skyline next to an s13.. not much comparison looks wise i dont think!!!
Stock for stock.. modified for modified a nice Skyline will always outdo a s13 in my opinion (180sx can look VERY VERY hot though..) but still not the interior comfort and options u get with a Skyline.
I had an s13 sr20det that was black, lowered on stock wheels, dewinged + debadged. Everyone thought it looked and went way better than any r33 boat.
Its personal opinion. Some silvias might look better than your boat, your boat might look better than most silvias.. because lets face it.. they cost less to buy so their owners cant usually afford to make them look good.
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
