Hey Peeps,
Though i might introduce myself in the ACT thread! Well firstly if i dont reply its not cos i dont wanna its cos i dont have the internet much atm, but once its connected youll see me on here heaps!
I just sold my 250 rwkw soarer for a standard skyline, kind of always wanted one but was after something stock and manual :) well i got that
My beast wagon is a Maroon manual series 1 r33 with zorst and thats about it, looking at doing a few little things like fmic, dump pipe small things like that and some hids cant believe how bad the lights are on it.
Need to sort out a miss that it has on idle, ive cleaned the afm to no avail. Might try the idle controller thingy (tip from a fellow liner)
Anyone on here interested in or does powerlifting as a hobbie?
Kind Regards
PK
https://www.sau.com.au/forums/topic/218644-newbie-to-the-skyline-world/
Hey Peeps,
Kind Regards
PK
Welcome.
Also could be a coil or 2 arking to the head before getting to the sparkie. Very common occurance. Remedy:New splitfires etc or new standard coils. Way to test, borrow someones working coil and replace each one, one by one untill it stops, if not, then maybe something else.
I would assume the usual Autobarn etc places would have it. If you talk to Nathan (Nath32) who usually works at either Belco or Fyshwick Autobarn and get chumy, you might be able to score a discount on stuff.
@ testing stuffed coils.... I think you'd be lucky if just one was stuffed. I had 2-3 that were stuffed. If you want to find out if it's the coils, remove the coilpack cover, go for a hard drive at night, pull over and pop the hood, stick ur head in and see if u can spot the arc'ing. It's dead obvious :P
Welcome!
I will be in the same boat i will need gps for the first month. I dont move there for another month should have our house in a week or two.
Welcome well sort of since i dont live there yet.
So why did you move there?
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
