I tried to leaner my car(BNR34) with the PFC, but I can't!!
I have the following mods:
HKS valve spring step 2
Jun 264 cams IN/EX
Jun cam sprockets
Jun Oil pump
HKS 1.2mm Head gasket
Nismo N1 turbos
Nismo fuel pump
Apexi Power FC
600CC injectors
Anyone could give me some ideas? When I rev up the car to 3000rpm, the engine light flashes and would go up further?
please help!!
Edited by BNR34boy
https://www.sau.com.au/forums/topic/218650-how-to-leaner-my-car-with-the-pfc/
How do you know it needs to be leaner? The flashing engine light possibly indicates overheating of the catalytic converter- probably caused by lean A/F.
What does the O2 sensor say on the dyno?
whenst the last time you calibrated the sensor? how old is the sensor? how much are you changing the fuel map (how much did you take out, as a percentage of the original nuber)? did you take a bit out, then test it, and repeat, or just take heaps out and now its having that problem? did you at least save the previous map it had before you started messing with it?
