Make:Nissan
Model:Skyline
Milage:108000
Transmission:Automatic
Colour:White
Complied?
RWC supplied?
Currently registered? YES
Price: $9300 or N.O
Contact: 04 33968069/ 02 98092318
Comments / Modifications: 3-4 inch exhaust, HKS Pod filter, 17 Deep dish wheels
Images:
Edited by sahas20
Yes guys but No one to buy it. rear end dent is a very minor one. It can cover up using a bodykit. Need money ASAP to buy a new RAV4. Seller is waiting So this has to go. Make me an offer !!!!!!
HI Guys,
It has 2.5 months registration and you have to spend $ 400 -$450 repair the dent and paint it.There arent any problem in this car. Engine runs perfectly and very smoothly. Gearbox is working perfectly. I 'm selling this to get my new RAV4. That's why it's so cheap. My seller is waiting to get his money and i need to sell this ASAP.
I dont know why people dont like R33 but i love it.It's the only sports car with power and comfort together. If you have money you can buy a M3 .but in $10,000 range this is the only car with comfort and power.( To my Knowledge).You can't get this comfort from a WRX,EVO,300zx. anyway thanks for your comments.
This is a great bargain to anyone. call me if you want to inspect the car.
0433968069/02 98092318
It will cost you less than $2000 for parts( Everything). If you need i can get it for you with the car for $11,000. To fit this it will cost you around $500-700. I can complete the conversion with the car for $11,500-12,000.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
