Yes guys but No one to buy it. rear end dent is a very minor one. It can cover up using a bodykit. Need money ASAP to buy a new RAV4. Seller is waiting So this has to go. Make me an offer !!!!!!
lol sorry but i found that comment hilarious...must need a pretty big kit to cover up that dent.
but anyways wont cost much to fix that damage. hope you sell it soon. gluck
Thanks for your comment anyway.
I know it's hard to cover it. why i mentiond it because i tried to repair the dent and put a body kit.The seller told me that it's not important to do the repair because i can cover up most of the damage from the rear kit. I know it will not cover 100% damage.
Thanks
Price Dropped $8,900 ONO. Common guys.This is Freakin Cheap. I need to sell this before next week. I need to get my new RAV 4 :D
(Actually my Wife needs to buy it.I prefer to keep this). ANy reasonable OFFERS. ?????
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
    • I only use rubber also. I have an intense distrust of silicone for coolant.
    • Clamp meter will probably tell you lies. PWM DC looks a bit like AC (because the voltage is going up and down rapidly), but it is not AC because the voltage never goes negative and the current never reverses direction. But because it looks like AC, and it is happening at high frequency, at can cause wierd reactive effects. Just be warned that you might learn things that are....confusing. Because they aren't necessarily real.
    • Appreciate the detailed response! It's all new technology to me and your suggestion for reducing DC and finding sweet spots seems like a great approach.   I'll chuck a clamp meter on it at the same time and figure out whats happening at different settings to get a good understanding.   Will report back with my findings when I get around to it to help anyone in the future that will be in the same situation as me 😁
