Im posting this thread for everyone's knowledge on what parts to achieve what horsepower on a RB25DET since ive searched on the forum for PROCAMS and nothing came out.
So here it goes..
Ive waited 3 months for parts and headwork on my Skyline R33 RB25DET.
Currently its in a process of installing all the parts in.. finally.
Parts loaded was :
1. TOMEI PROCAMS 260 degree 10.25mm lift exhaust and intake
2. TOMEI Cam Gears
3. TOMEI 10.25 Lift Type B Valve Springs
4. TOMEI Solid Lifters
5. TOMEI Adjust Shims
6. COMETIC 1.3mm x 2 Layers
7. GARRETT GT35R Ported Shroud .82
8. Top Mount Ex. Manifold
9. TIAL 43mm Wastegate
10. HKS Type R 600x255.6x103 Intercooler
Was getting 192kw on wheels before this with stock internals.
Just a Apexi PFC, HKS 2540 Turbo, HKS Oil Cooler, HKS Intercooler (Type S), Greddy Boost Controller and Minor Upgrades.
Will keep this thread posted once the car is running and dynoed with the new parts installed. Car will be out this week. I hope...
Cheers!
hey guys,
Just got the car this weekend. Car is slightly tuned for road drivability.. Havent got the time to do a full tune atm.
For the solid lifters conversion, its pretty tedious work. Shims have to be added and measured.
Im totally unsure about what CR my car is running. The car started up alright. Nice idle and timing is great. When revving, the sound is awesome!
On higher RPM it sounds sharper, no joke but it sounds close to a Ferrari. =)
Im worried my oil pump will give way one day but will change it soon to accomadate the revs.
The turbine spools great. I just dont know how to put everything together. But everything just sound crazy guys!! The turbine has a pretty much like an aircraft spooling sound.
Hope to get my car tune tommorrow and will post up the numbers soon! Keep watching guys!
Cheers!
I can feel boost coming from 3300 rpm onwards.
No lag, nothing. Its insane to hear the turbo spools and the power is just crazy.
The turbo is a Garrett GT35R with ported shroud. I was worried when i installed the turbo because of lag.
But everything is going on well.
i am looking at doing the cams on my rb25det and cannot find anything at all....so this is really handy cheers mate
hey Krishy,
For Poncams is just plug and play.
I will recommend Poncams. Safe the hassle and money!
what you mean by ported shroud? Im assuming modified comp cover? And this gives hks spooling sound?
  • 3 weeks later...
  • 7 months later...
Did you ever get this tuned??? Am looking into bigger cams and solid lifter conversion at the moment.
Have Tomei 256 cams already. And have just has some issues on the tune with my 25/30 and had a rattle thru the top end after a few power runs @ 8200rpm.
What is the cost for a solid lifter setup???
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
