having attempted to use this "tomei solid lifter conversion" i highly dont reccomend it.. i know of some brand new tomei buckets and type B valve springs if someone else wants to have a go..
extremely unhappy with the fact that they required such large lashcap style shims 5-6mm+, was easier and cheaper to have JHH convert the hydrolic lifters to solid.
that was the case in the head we went to set it up on anyway.
Edited by Cartman
Very frustrating to read these threads and not get the ending. Did the Tomei man get his engine to run properly, make decent power?
I take it you would be recommending Poncams as a simpler job with good power for the street?
Really depends on the setup and what your aiming for. if you want to do the solid lifter conversion while rebuilding the motor i highly reccomend getting JHH to do it for you great workmanship and excellant porting.
however i wouldnt reccomend the solid lifter conversion if you arent goin to take advantage of having it done.
Edited by Cartman
Who is JHH???
John Hill engineering here in Brisbane.
I am with cartman, the tomei conversion is a donkey f**k. John did my conversion and head work and couldnt be happier.
my understanding is when going to a solid lifter from a hydraulic is that you will require new Valve's as they are an extra 5 mm longer to suit a solid conversion and take up the extra spacing or shim thickness required.
I went through all this when i installed hks 256 deg in and 264 deg ex cams with upgraded valve springs.
My lifters bleed out after a while when the engine is not running from the extra tension in the springs. I explained this to my engine builder who at the time has not done any upgrade's on a 25 b4. I was going to convert to solids to try and illiminate the proble but then engine was together and thats when i found out that you require different lenth valves to suit
What was the cost for the conversion FineLine??? Also any idea of freight costs from Tassie to Bribane??
Dont hold a gun to my head because i really cant recall the pricing but i believe it was somewhere around the 6/700 dollar range for the conversion, My bill was a fair bit more than that because i did some o/s valves, heavier springs and some major port work to boot.
It worked out far less expensive than going to a 26 head because i already had a greddy plenum and himount manifold etc to suit the 25.
Plus throw in the cost of buying a 26 head and you soon realise its very good value to convert the 25 head to solids.
Sounds like you have done what im planning on. Was he good to deal with? Any chance I could have a spec list of your setup and how much it can flow? Am now looking at bigger cams but not sure whats "to big". It will be on a 25/30 with T51r and a 8200 - 8500 rev limit.
both john & will @ jhh are both champs. john is semi retired now i believe so its mainly will and another bloke there.
will is just like john though, he recently did a big head for me and it came out spot on how i wanted it, perfect
noels (fineline) only got baby poncams in his head, he also runs a 35r .82rear, i'd be looking at 260-280deg 10.5+ lift for ur setup, but depends on how much coin u want to throw at it. the head i got done has 1mm valves both sides, dual springs, ti retainers, bronze gudes, big port work, intake 270 10.8 exhaust 280 10.8. its on a 26/30 with a t51r kai, rev limit will be where it stops making power. no numbers yet as its waiting engine mounts to go back in
  • 1 year later...
I see what you mean Cartman. Just by sitting the type B spring and solid lifter in the head its easy to see that its going to need a fairly decent sized shim in there. Might just put them aside for another build that may come along lol.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
