Just did some back to back testing on our car with HKS low-mount balance pipe manifolds.
Our car runs HKS GT-RS turbos and the car suffered from the dreaded turbo shuffle. This is not a problem when racing but on the street it made the car really frustrating to drive. As the car started to build boost it would 'choof' its head off.
Replaced the HKS twin low mount manifolds with the balance pipe items and 'hey presto' problem is completely gone. The car is a lot more streetable and driving on the road is now a lot less hassle.
But....
It seems to have softened the car up a little, not coming on boost as hard and appears to have lost a little bit of power overall. Will be dynoing the car on friday to see if my observations are correct.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/218709-balance-pipe-manifolds-on-rb26/
id say the shuffling is as GTR said is from the twin scrolling style setup, across the manifolds
when you use the balance pipe, it does as the name implies, balances the exhaust gas across the manifolds
but that probably gives a drawback and takes away the splilt pulse style setup
i think i had a similar problem with my gtr, tho i didnt really care too much for it.. i can make the car do it for pretty much the length of the m5 motorway.
it often sounds like a chu chu train just when coming on boost slowly, does not really happen with wot. or notice it then anyway.
angus smart that is the one lol.
especially on the freeway, it does it all the time, unless you give it enough throttle for it to take all the air, then you spool up instead, and let off to slow down and then resume chu-chu, chu-chu-ing.
wouldnt be so bad if it was just quieter
up hills on light throttle was murder
wonder if turbo shuffle affects the R35? haven't read any comments suggesting so yet...
I doubt it, as the turbo systems are completely separate, for the same reason the z32's dont seem to have the problem. I wonder if the shuffle is the turbo's causing each other to go into surge, and building up a pressure harmonic between the two?
Edited by Adriano
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
