Hey everyone,
I'm currently in the process of tuning my car and am having trouble getting past 5500rpm. Or to be a little more precise, it won't go past 5500rpm.
Mod list:
Rb25det running on rb20 harness
Greddy Intake manifold
Q45 throttle body + rb25 tps
Greddy top feed 10.5mm fuel rail
GTR injectors with resistor pack
HKS 2535 Turbo (10psi internal wastegate)
Turbo back 3 inch exhaust
FMIC
Greddy Emanage Ultimate
Nimso AFPR
Sard r2d2 atmospheric bov
Bee-r rev limiter
So in any gear, any throttle position as soon as I hit 5500rpm, the car hits what feels like an ignition cut. (Feels like the factory speed limiter.) Its runs flawlessly before it reaches that figure. According to the logger, the ignition isn't breaking up and the air fuel ratio is fine.
Its not a boost leak, nor a coilpack problem, the maf seems fine its reading up to 5 volts so I don't see anything out of the ordinary there.
The guy that is tuning my car has a lot of experience with the emanage ultimate, he went on various courses to learn how to tune it so I think he is not at fault.
Checked for codes before and pulled up a 55, no malfunction.
If anyone has any ideas what could be going on I'd appriciate your input.
Thanks in advance,
Jay
https://www.sau.com.au/forums/topic/218719-unknown-ignition-cuttuning-trouble/
get rid of the BeeR limiter, the above picture is a result of using one of these limiters. it was in a week.
Rb20det_pinout.txt
i dont have a pinout for the rb25 handy, however if you do find one compare the numbers and description for the both,
you may want to check the tps and afm using different pins on the ecu's,
pluging the 20det loom into a an ecu designed and programed for a rb25 for example will missmatch these pins.
but 10 bucks says its the limiter.
I have similar problem. I have R33 gtst auto with electronic boost control, 11 psi, std turbo. Sometimes boost spikes ( for whatever reason) past 16 psi and wham! power cut, then ok again. Could be cold air, i have voltage bender to lower afm voltage so it does not max out. Still happens, i reckon voltage bender needs gentle signal increase. If its a sudden spike from say 0.5v to 5.5, its too fast for processor. This is all i can think of coz it's pissing me off to tell the truth.
I removed the bee-r rev limitter so its not that, checked the tps doesn't appear to be that. Also retarded the timing a bit and that didn't help.
I'm going to wire in my z32 maf after work tomorrow and I'll let you guys know what I come up with. I wish I'd have bought an fcon, thats all I'm going to say.
yeah, i was lucky enough to get my hands on a HKS Fcon pro V fuel/ignition system there brilliant,
every dynamic can be tuned at every 100 rpm interval, then it can self learn after that.
thats cause the factory ecu's boost cut a 16 psi.
Dude! I always suspected that, thank you so much for confirming that. I am not being sarcastic, just glad that the problem is diagnosed and not in the realm of the unknown anymore.
Happy times!
There is no boost cut, it would need a map sensor for boost cut. There is an excess airflow cut, which is a different boost for different turbos/modifications.
Edited by Adriano
Impressive :P
How have you theorized that the spark cut bent that rod though??
... Not being a cock, just thoroughly interested.
Edited by GeeTR
  • 1 year later...
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
