Saw u guys leaving the bay last friday and im pretty sure it was ur car poppin flames at the lights :D (search bee*r rev limiter on youtube). so i asked do u have a bee*r unit or were u just hitting the normal limiter coz u were bored waiting 4 green :(
oh yeah that was me and my brothers girlfriend's car we were mucking around :P it was normal limiter my lil girl is just runing rich atm so flames are easy :P
  • Replies 274
Posted Images
yeah no worrys kellie ill have to say hello this time and i will ask how long things are going to take hahah but its all good no fuss love being out with skylines! i drive a gray GTST which has a Full GTR front if that help coz have no idea who you are!! in that fact anyone really on SAU inless there my mates so come say hello people :(
and waiting for me and Pete to get back with the R
when we stopped at the bay we were chatting to mates on here and waiting for some others from here as well, some times its good stop to chat with ppl then you actually meet ppl that you type to on here.
from what i gather everyone had a good time and enjoyed the chatting and cruising see the thing is the cruise wasnt even half over when you left so had you stuck around there was plenty more driving and hills as well,
oh well maybe next time hun and if you want to go or see how long we will be befor we leave just come ask :D
works both ways saying hello
yeah no worrys kellie ill have to say hello this time and i will ask how long things are going to take hahah but its all good no fuss love being out with skylines! i drive a gray GTST which has a Full GTR front if that help coz have no idea who you are!! in that fact anyone really on SAU inless there my mates so come say hello people :P
i was thinking of doing a sunday cruise to victor or murray bridge just an easy child friendly cruise to go have lunch somewhere in a few weeks and then we can take pictures to
Hiya
I think the last place was an awesome meet spot. sadly i have to go and abuse my liver on friday night with my colleagues, but I'm definately keen to go on a victor or murray cruise... tho last time i went to victor there were roadworks (and stones!) that chipped my front bar....
murray would be nice, and we could do a bbq at puzzle park or something? *shrug*
-D
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
