Hey
I am after a different spring for the older style HKS external gates
Looking for something around 14psi - Just wondering if anyone knows where I can get one from, or a part number or something similar for the one I need
Can I use a spring from a differnt brand of external gate?
Are they all the same/similar?
Something around Melbourne preferred - Will swap for my 0.7 bar (10 psi) spring if anyone wants
I have also attached pictures of the HKS external gate I am referring too
:P
https://www.sau.com.au/forums/topic/218735-hks-external-wastegate-spring/
TiAL 44mm
10psi spring
Height - 600mm
Width - 106mm
Wire Width - 4.8mm
5psi Spring
Height - 475mm
Width - 35mm
Wire Width - 3.75mm
PS: Too tired to test bind height, but it cold be guesstimated i assume.
If more users posted various gate's and springs, you could find something your after.
GL
I need to know where I can get these springs from
Anyplace that sells a particular gate, should sell the manufactures extra springs as well, be it here or the US / Japan.
Would TiAL and HKS wastegate springs be similar, would they be interchangeable?
No idea, but they wont if they're not the correct size. They could not seat on the actuator top or hat center, or even bind on each other (if running two springs)
But those of similar dimensions (inc the gates actuator internal dimensions) will be ok.
i think you need a new ruler.....
I think your right - was tired. Id assume its 60mm, ill check again and edit in the morning
:P
EDIT: course you cant EDIT posts over a few hours old on SAU, which is teh ghey.
Those X and Y figures need a decimal place between last and second last digit obviously ;)
Edited by GeeTR
