hey guys, just quickly, when we speak of '4 deg retard' or 3 or whatever, are we talking 4 deg of cam gear adjustments notches or 4 deg of crackshatf movement? as from what i gather 1deg of cam gear movement is the equivelent of 2deg of crackshaft movement...
https://www.sau.com.au/forums/topic/218772-cam-gear-adjustment-question/
we are talking about o of cam movement. so 4o retarted would be 2 marks on the cam gear if it is 1 mark = 2o.
sorry I just reread the question and can't confirm whether it is crank or cam o. But for sure the measurements you hear mentioned on here are relative to the marks on the cam gear.
getting individual degrees onto the cam gear would be pretty hard to do, let alone look at them properly without some magnificication.
4 degrees is generally accepted as benificial, however there are underlying assumptions about the setup. There is no substitute for testing to get it right for your car. I have done a few cars and there can be a little variation on that figure either way that has actually quite a bit of impact.
here is a pic of my gear....now i know that each mark = 2deg of crack as it states on the gear
what im asking is when somesays i 'retarded the cam gear by 4deg' are they talking about crack 4 deg or gear 4 deg (= crack 8 deg)???
I couldnt help myself :)
Edit, I took it to mean, 4deg at the crank. So two marks on the cam gear.
Edited by GeeTR
yeah sorry iw as too lazy to check, the car is under a cover. but the trust ones are the same I am 99% sure. 1 mark = 2o crank. So people are talking crank degrees.
BTW when setting my gears the other day we tried 8o on the intake and lost 40kw just like that. very small adjustment makes a very big difference
how do you get 4deg retard on the exaust gear?
To retard the exhauits cmashaft 4 (crankshaft) degrees, you rotate the camshaft 2 slots anticlockwise, because the engine turns clockwise.
The camshaft is connected to the centre of the pulley, the cambelt is conected to the outside of the pulley.
You keep the outside of the pulley (the cambelt) still while you rotate the inside of the pulley (camshaft) anticlockwise.
Simple isn't it?
Cheers
Gary
OK I've tried the following on the exhuast cam, base timing was adjusted to 20 degrees each time (auto)
4 degrees retarded (car seemed less responsive, could dial in a fair bit of base timing though, didn't seem to drastically improve matters) Had to drop EBC gain to 20% to not go over 0.85Bar
2 degrees retarded (much the same as before, more response) Had to drop EBC gain to 30% to not go over 0.85Bar
2 degrees advanced (seems to have picked up a bit of power) Had to raise EBC gain to 40% to get 0.85Bar
Now this is the same setting as another SAU'er told me he was using and picked up about 10rwkw on the dyno.
My next thing to try is adjusting on the dyno when it's getting tuned and see the real results.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
