Engine Bay Pictures
  • Replies 248
robots - its a complete custom wiring harness only thing I've used from the old harness are the plugs then i hide everything and re-route it all and wire it all up inside the car
how much did that sorta setup set u back? i wanna do some engine bay detailing, and have no idea how much this sorta stuff costs
With all the re-wiring etc its a 4 figure adventure.
I've seen the time it took a owner during rebuild to re-route the entire engine bay (dash out etc)
Looked trick but took months just on weekends etc. So to pay a workshop with overheads and so on would be substancial.
that sux, im not looking for anything crazy, just something neat.....but far out we takn g's here.....
to detail and engine bay like mine the motor has to come out because i detail everything including painting the motor
rewires usually take about 3/4 days and i charge between the 1 & 2K mark depending on how far you wanna take things
wat is a ball park price for the average guy who comes in, wants most of the ugly wires tucked away, bit of polish here and there and thats it.
$1500 and up depending on how far you wanna take things
polishing and chroming is where things really start to get dear
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
