  • Replies 248
From everything i have read there isnt good even flow to all 6 cylinders and the first 3 tend to lean out more. However one of my mates had a stock plenum with the throttle body welded to the front and it drove fine, so i personally wouldnt worry about it too much.
some insane engines in here.
antsrb25 how are u getting away with the afm being that close?!?!
Havent had any problems with at all mate.
Also no issues with the modified plenum either. Making around 280rwkw with no problems.
well today
we got the polishing stuff back from Buff It....thanks MAX for picking it up for me and we worked till 11:30 at Keep Performance LAb.
got the diffuser back on, intergrated the Greddy Gracer rear mud flaps (no pic)
then putting the polished items on..
I know with everything polish, it will look VERY RICED out and makes me feel BROWN....as u know all the Brown ppl's civic has polished engine bays....but i had to make it polish because that's the only Colour the GOLD fittings would go along with...how i had the pink valve covers...it didn't do too well with the GOLD.
here are the pictures
1) engine bay VERSION ONE GOLD PINK PURPLE
2) engine bay VERSION TWO POLISH GOLD
WE ARE GOING TO DTP !
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
