Item: Tomei Reytek programable ECU with map sensor
Age: 1-2 yrs
Condition: Perfect
Price: $800 ono
To Fit: (What car) R32 GTR
Contact: PM or 0422382292
Comments:
This is a fully programable ECU which uses a map sensor to eliminate afm's like the D-jetro PFC. Im basically selling it as I couldnt find anyone at the time to tune it in Brisbane. I know that Unique Autosports in NSW sell and tune them, and some DR Drift (cant remember name)in Vic and a place in perth but could be more that do now. You can buy the tuning software and iterface kit from tomei for them too.
I pulled it out of my car which had it installed in the Tomei workshop in Japan along with other things. The car was running around 310awkw (mercury motorsports dyno)with T04R turbo (17psi), tomei 260 cams, upgraded pump and still with standard injectors. Car ran 11.5@126mph with that setup and was getting 500kms per tank of fuel. I have since upgraded many things and swapped for a PFC d-jetro cos no one tunes it in Brissie otherwise I would have kept it!
Unique autosports sell them for $1900 exchange---> http://www.uniqueautosports.com/ (look in the tomei section)
for more info ----> http://www.tomei-p.co.jp/_2003web-catalogu...dex-reytec.html
OTHER THINGS FOR SALE:
One set of R32 GTR injectors with fuel rail and nismo adjustable regulator. Was running 310awkw safely which led me to believe they might be highflowed but not sure?? Might need new buckets which can be bought from an injector place for a few dollars or less. Were running fine and pulled off for bigger items.
$400 for the lot. Will not separate
One GReddy 60mm black face mechanical boost guage. In perfect condition and working fine. Was in car when bought a replaced for a Defi guage. Just needs vacuum line to work.
$100
Chrome catch can which I bought a while ago. Still new in box with all parts required.
$30
RB26 cam gear front cover and stock cam gears in good condition
$75
RB26 oil breather U pipe between cam covers in perfect condition
$20
RB26 clutch pack fan. Was in good working order and not slipping. I have grinded a little off the edge off the blades as seen in pics to clear the radiator I put in. I went to thermos as the shroud couldnt be used. The grinding hasnt done anything to performance of fan.
$30
If interested either reply, PM or call me on 0422382292. Will post interstate at buyers cost. Prices are neg.
Cheers,
Glenn
Edited by 06tst
price drop on Tomei Reytek ---> $700 ono. I need this gone asap!
It is a great ecu and fully tunable. If you are in Sydney and looking for a cheaper option programable ECU this is it. Unique Autosports deal with them in the western suburbs (seven hills) of sydney and can tune them.
Also Melbourne people, DR DRIFT can tune them aswell. He is also in western suburbs at Brooklyn.
i can tune thenm also, whats your best price?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
