this thread will be on the last page in a few days time :-)
Im chasing a set of clear front bar indicators for the S1. Ive heard that nissan altima (bluebird) ones will fit, but the aussie bluebirds came out with orange?
Where can i pick up a set of these? the clear side indicators are on ebay everyday for about $60 (nismo items) but the fronts are proving harder to find.
I havent bought the sides yet, waiting to get fronts at same time so if anyone has a set for sale let me know eh.
Can anyone help out?
yeh he is an ebay power seller haha... i looked through his online store. doesnt have any of the clear fronts, but has a heap of side indicators. im just hoping to get a set of fronts without having to go to yahoo japan
yeah leshy thats what id mentioned in the first post, but the issue is they only released them in aus with the amber ones, not clear. ill wait and see what performance wise comes up with as an answer, as the orange look ghey on a black car.
forget about clear ones everyone has those :P , buy a can of nightshade, give e'm a couple of sprays and a polish and you've got black on black, now thats not ghey ;)
leigh i was actually thinking about doing that to the clear ones, as i wouldnt have to put so much on to get rid of the orange look. the taillights are being tinted.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
