Make:1989 r32 skyline
Model:gts-t 4door
Milage:176,000
Transmission:manual
Colour:black
Complied? NO
RWC supplied? AS IS
Currently registered? NO
Price: $4500 ono
Contact:Kris on 0450245382 or email: [email protected]
Comments / Modifications:Ok , I bought the car imported for $8000 with 70,000 on the clock had to put an exaust on and air filter and sway bar,The two front rotors a slotted,cd/mp3 player, thats about it for the mods very basic, dont really thrash my cars anymore ,Im getting old dammit!!
DAMAGE: Car was brokin into a while ago when I was over seas and havent had the time or money to get the big girl back .... So IT NEEDS:
1---- key barrel ignition thingy
2---- windscreen (cracked)
3---- Rear end has some damage but may be able to get fixed thru insurance (it was hit while parked ,Boot lid is fine but rear bumper is banged up a bit)
4---- It has developed a miss on cyl 6 then 2 (tryed different coils,my friendly mechanics say its possibly a gasket)
5----Maybe a new AFM It might just need a good clean.
6----Very small eletrical work ,like fuses 2x indacator bulbs
7----It hasnt got A/C but I have the bottle if you want to go gas it up.
8----1 tyre definate maybe 2
9----New hose that goes to the boost sensor thing see pic
AND THATS ALL I CAN HONESTLY SAY!!!!!
IT WOULD BE GOOD FOR SOMEONE THAT HAS GOT THE TIME AND MAYBE THE PARTS AND THE KNOW HOW ,YOU MAY NOT HAVE TO SPEND MUCH AT ALL TO GET IT GOING.
IT NEVER BEEN DRIFTED NEVER BEEN THRASHED JUST NEGLECTED.
THE CAR IS ON DISPLAY NOW!!!! IT ON THE GOLD COAST HWY AT BURLEIGH HEADS JUST NEAR THE BURLEIGH HEADS MC DONALDS 10METERS NORTH OF MCDONALDS DRIVE WAY....
1971 GOLD COAST HWY TO BE EXACT.
BUT OFFERS A WELCOME.
Images:WILL HAVE A PIC OF THE REAR DAMAGE AS SOON AS MY CAMERA CHARGES AND IT HAS A SWAY BAR NOW MY MATE JUST GAVE ME.
https://www.sau.com.au/forums/topic/218830-4500-for-damaged-r32/
Model:gts-t 4door
Milage:176,000
Transmission:manual
Colour:black
Complied? NO
RWC supplied? AS IS
Price: $4500 ono
$3500 anyone
hey all got some new pics $2500 as is needs small engine work, new windscreen, key barrel (bloody mongrels) ignition, panel work on rear bumper, check all fuses and indicator bulbs,
and 1 tyre needed maybe 2.
Good for someone that has the time and maybe some good mates to help get the black pearl back on the streets,
AND IT IS COMPLIED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Man, is your phone turned off, I've been trying to call you all afternoon, I'm quite eager to buy this. When you say it's not registered, do you mean that it just doesn't come with registration, or have you already unregistered it and surrendered the plates?
Basically I want to know if I'd be able to drive the car home then give you a lift back to yours (with you taking the plates with you). Obviously I'd have to bring some tyres on rims with me.
Call me 0432 848 627 - Luke
Edited by daisu
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
