You can do the valve springs with the head on but its a long and lengthy process that is costly unless you can do it yourself. I have heard of re-using metal head gaskets but i wouldnt say it would be advisable especially if the engine is highly strung.
Talk to JHH in woodridge about the work. Ask for John or Will.
https://www.sau.com.au/forums/topic/218851-head-gasket/#findComment-3860435
Any on else have any imput a couple of people have told me it can be reused
hks that is
but what about changing valve springs what have people out here put in neos
I have tried to re-use the HKS 1.2mm head gasket on my GTR34 to change the valve spring, unfortunity the compression was not that good and y mechanic told me it is leaking. So, i suggest you might want to get a new gasket so you don't have to spend time and money to do it over again.
https://www.sau.com.au/forums/topic/218851-head-gasket/#findComment-3888251
