Brand new "100% GENUINE HYBRID GT SPEC INTERCOOLER KIT FOR SKYLINE GTS R32, R33, R34 - Core Size : 600mm x 300mm x 78mm - Tube & Fin Design
NEW DESIGN, BETTER FLOW, PERFECT FIT
R32 GTS RB20DET
R32 GTS-T / GTS-R RB25DET
R33 GTS-T / GTS-R RB25DET - As will be seen on Ignition DVD Budget Build Up in June 08.
R34 GTT RB25DET
New product catalogues out now!
IMPORTANT NOTE:Hybrid Development International Pty Ltd is the official and legal owner of the TRADEMARKS, Hybrid and HDi Logos. Buying through this forum guarantees that you will be getting the quality and authentic Hybrid Performance Product.
All kits will come with an authentication plate !!
"DON'T GET CONNED.....GET REAL POWER!!!"
HYBRID DEVELOPMENT INTERNATIONAL (HDi): Through our extensive research and development in our Testing Centre our uniquely designed intercoolers and Intercooler kits have always been the first choice by leading performance Tuners WORLDWIDE.
The new GT spec intercooler kit has much less pressure drop compared to our already highly efficient bar and plate design and is 40 % lighter in weight! Carry the POWER and not the WEIGHT!! Only 6.2 Kgs
The ultimate performance is guaranteed as there is less restriction on the turbo compressor wheel which leads to a freer flow on the exhaust turbine wheel. HDi GT spec effectively reduces the turbo lag as well as widens the power band and increases maximum power with less engine stress.
Superb performance over the same size bar and plate intercoolers against pressure drop, efficiency, reliability.
Work of art finish (go hard with style)
Core Size: 600x300x78
Inlet/Outlet Size: 3"
GT spec Ultra low pressure drop 0.5-1psi at 23psi
Normal Bar and Plate 2.8- 4psi at 23psi
*All kit contains one latest Hybrid GT SPEC Intercooler, all necessary brackets, screws & nuts, HDi silicon hoses, POLISHED aluminium piping and stainless steel HDi Super Clamps
*All piping kit comes with a step-by-step pictorial instruction for easy DIY installation
* 1 year manufacturer warranty
Patent registered design
With
New leading Traverse Aero Dynamic Heat Transfer Element (TADHTE) technology!
SAU MEMBER Price ONLY $529 plus shipping
Includes Free Earthing Cable kit RRP $29.95
Easy to install, and Universal Fitting
Improves sound quality, bass, and high frequency
Improves Engine Response
Voltage Stabiliser
Quicker Engine Start
Cost Effective Results
Kit Includes:
Easy to follow Instructions
4 x 8 mm cables - LENGTH: 1x 55cm, 1x 70cm, 1x 85cm, 1x 1mtr
Gold plated Terminal Block - fits 14 - 17 mm terminal
Connection plate
Gold coloured screws
HDi Hybrid Development International
18/36 Abbott Road, Seven Hills NSW 2147
Ph: 02 9620 7388
https://www.sau.com.au/forums/topic/218873-genuine-hybrid-performance-products/
  • Replies 62
Posted Images
R32 GTS RB20DET
R34 GTT RB25DET
With
Forum Price ONLY $529 plus shipping
Ph: 02 9620 7388
Any chance of this same kit for a 2000 model RX7?
  • 4 weeks later...
Ph: 02 9620 7388
GT SPEC Intercooler - 600x300x78mm 15 Row Tube and Fin Core 700HP - $425 plus $25 Delivery (pick ok)
RS SPEC Intercooler - 600x300x94mm 19 Row Tube and Fin Core 900+HP - $525 plus $25 Delivery (Pick ok)
Recommended and used by Ignition DVD Budget GTS-T Drift Project (GT SPEC), Fast Fours - Superlap project S15 (GT SPEC) and R32 GTR (RS SPEC), HPI Magazine - GALANT VR4 (GT SPEC).
PLEASE NOTE:
Hybrid Development International Pty Ltd (HDi) is the official and legal owner of the TRADEMARKS, Hybrid and HDi Logos. HDi has been manufacturing Hybrid Performance Products since 1994.
HDi does all its own Design, Testing & Manufacturing (D.T.M). We are not associated with any other company nor do we source our parts through another company or make them in the same factory. You are dealing direct with the manufacturer and not a middleman. Since June 2007, we no longer have a sole distributor in Australia. This company had its dealership terminated due to hi jacking our trademarks and patents which is poor business conduct, this has been legally pursuant. We would also like to point out we have never stopped production or changed our name to release a new product. We have re-established our own operation in Seven Hills, Sydney, PH: 02 9620 7388</SPAN></SPAN>
RRP $29.95 - MEMBER PRICE $20 Plus $6 Shipping Australia wide. (1 x Vacuum Distributor Only)
AS SEEN IN HPI Magazine Issue 92 Special Feature
No More SPAG-BOG...Tidy up all those Vacuum Hoses Today
  • 3 weeks later...
HDI-SBC-D-EVOLUTION
</FONT>
ONLY $329.00 for MEMBERS
PLUS $20.00 Shipping Australia Wide.
HDi Super Boost Controller Type-D EVOLUTION
SBC-D-EVOLUTION
This boost controller has been designed for universal fitment to any turbocharged vehicle. The HDI-SBC-D-EVOLUTION provides the driver with precision boost and accurate display and measurement.
Product Features:
  • HDi Super Electronic Boost Controller with Dual in cabin adjustment
  • Closed loop boost regulation
  • Fast target boost locking
  • 120psi Pressure balanced solenoid
  • Micro Processor controlled
  • Rigid aluminum casing
  • HDi SBG-D Plug & Play Boost Gauge with Day & Night theme
  • Peak hold and recall function (with HDI-SEBS)
  • Dual read out both Digital & Analogue Display
  • Dual Measurement PSI & BAR
  • Full 270 Degrees sweep dial provides superb visibility
  • Advanced full electronic stepper motor drive
  • High Intense light emit diode back light for high visibility
  • Universal easy installation
Product Function:
The HDI-SBC-D-EVOLUTION uses a high precision temperature compensated pressure sensor providing the precision pressure reference for your turbo boost control function. By employing a unique closed loop boost regulating technique, the boost fluctuation is minimized once the desired boost level is reached. The anti lag program minimizes turbo spooling time so that you can have Fast, Sharp acceleration while maintaining your ideal regulated boost level. The HDi Super boost Gauge Type D (HDI-SBG-D) employs advanced stepper motor technology for accuracy and fast response. Our dual display design shows both BAR and PSI in analogue and digital format simultaneously. This provides the driver with easy and precise read out in the shortest possible time.
PLEASE NOTE:
  • 1 month later...
WHY CHOOSE HDI?
CLICK the link for the reasons.......
PLEASE NOTE:
so a gt spec intercooler kit for R34 GTT is $425??? can i pick up???
Hi, GT SPEC Intercooler only $425, complete kit is $529. Pick up is ok, just advise when so we can pack the kit for you. Thanks
