how to change boost setting on a apexi avcr on mode A the car r33 s2 rb25 goes to 10 psi and after 5500rpm in shoots up to about 19
i want to try and set in to 15 the hole time on mode a also quick spool up
Thanks
https://www.sau.com.au/forums/topic/218893-how-to-change-boost-on-a-apexi-avcr/
AVCR's are great once you have a base line...
If its spiking all over the shop that means your gain is set way to high...
lower both values on the avcr and then just increase the base line until you have good gradual control over the boost...
then just adjust the value until you get your desired 15psi, always trust a separate boost gauge tho dont realy on the avcr to tell you wants going on... :P
atl, have a google for an english manual and it explains boost spiking and gain setting much better than i can
so i never used the scramble function as never needed it and i never used the self learning modes...
I always used mode number 1.Boost/Duty
So just to get a base line, reset the unit and start from scratch...
Set the Bst value to 1.05kg/cm2 and set the gain to about 10
Then go for a drive and watch you separate boost gauge and see what happens...
If it comes on way to hard and too fast for you drop the gain down, if it takes way too long to get to full boost then turn the gain up a bit (little changes like 3-4 at a time)
Once your happy with the gain and the way the car boosts then adjust the kg/cm2 value up of down (once again in small changes) until you hit the sweet spot...
Just remember a high gain will cause boost spiking as the valve in the boost solinoid will bounce and create boost spikes, so keep the gain value as low as possible without loosing performance and thrill... :P
sandy
the duty is the ratio of the solenoid being opened and closed
so a higher value, means the solenoid is closed more, which means it holds more boost
the lower the number, the less you should have, well as least inline with the target boost
so if you set say 1.0kgcm2 and 50 duty
and it ramps to 1.2kgcm2 instantly your duty is too high, ie: it's closed too much, and the actuator doesnt progressively open enough, so it opens finally, and its too late, its way over
so if you set say 1.0kgcm2 and 30 duty
and it climbs slowly but only gets to 0.80kgcm2 your duty is too low, ie; its open too much, and the actuator opens early and just lets all the pressure out
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
