I cannot thank Allan enough for his support over the past year.. my car has seen a few bingles lately and the most recent being the stack at lala on sat night... if anyone saw it, it was a huge hit and really pissed me off. I have Super 8 drift comp coming up this weekend and i honeslty thought my chances of driving my car were zero to slim.
Allan said to drop the car off and was absolutly convinced they could repair it in around 4 hours or so... i was somewhat doubtful but no... never underestimate a man passionate about what he does, and the results speak for themselves.
i can honestly say, that if your looking for a professional repair job for your car (import or not... they do the lot) then go and see Allan, Hayden, Scott and Paul down at All Type Crash Shp 3/ 1395 Main North Rd Para Hills West 5096, 8281 0130
i'll let the pics speak for themselves.
BEFORE
AFTER
https://www.sau.com.au/forums/topic/218900-all-type-crash-are-the-bomb/
  • Replies 71
Posted Images
wow dude they are good! if you dont mind me asking what do they charge for something like that including paint?? *** edit*** sorry just realised ur sponsered by them.. dont answere my Q
once theyve painted it it will look like nothing has ever happened :P
you're gonna have to call them or see them prices... no two crashes are ever the same. there are so many different variables that affect the final price.
but rest assures, they are highly competitive pricewise!
i can count at least 6 skylines down at All type atm!
Gotta add a funny story about Common whores!
About 2 years or so ago, some 10 jerk-offs from the SA forum of the Commonwhores website decided to get onto the main motorocycle forum I frequent and talk shit on it like "motorcycles are slow" and "bikers are gay car haters!" blah blah.
Well our 12,000 odd members at that time got them back by continuously posting "The only reason you're in front, is because thats where we want you f**kers!" :)
I believe they shut down the site "for maintenance" since it crashed something. :P
yup spot on.
one bloke in a 32, JUST bought a GTR bonnet, grill, bar, reo and guards for his GTST and fitted them all on, 2 days lator he was wating at the lights or something and this lady in a VT wagon just decided to floor it in reverse to try and go down a side street....
the tow bar distroyed the bar, reo, cooler and and lot of other shit!
morons!
Wow that had to suck! Just like me getting a new turbo fitted to my car and three days later having some old bag run a red light in a Kingswood and write off my car! :P
And DON'T say "Not the Kingswood"!!!! :)
hearing u guys makes me scared as hell to even put the damn key in the ignition
-D
ah good work by all type crash! metal finish by the look on the photos good job.
Metal finished???? :) Very few workshops do this and even fewer know how to do it well.
Looks like its been hit with a hammer and dolly then orbital sander to remove paint.
Those lines are way too rough yet, but im sure it will come back nice.
Mines one of them :) and no, im not a bad driver - the post ran into me. (i misjudged how close the rear gaurd was to the post)
Mines one of them :P and no, im not a bad driver - the post ran into me. (i misjudged how close the rear gaurd was to the post)
first MissR34 now you, wat is it with skylines and posts lol
but yea i can vouch for all type's aswell it took em half a day to fix my front bar and was back by that night.
job was perfect and couldnt tell the difference.
nice hit simon. who hit ya??
Thats a shame Simon car was looking insanely hot before that crash. But then again, I am sure you wont be able to tell the diference when its all done!
Have any clips or pics of the actual hit? Who did you hit? Hayden or Jack? ;)
Ric
Edited by Richo
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
