  • Replies 71
Posted Images
aaah the turn 1 tyres strike again aye. lol
i swear dumbest move ever by mallala, so many cars are gonna get damaged. howd that orange 86 look after lol
but yeh i guess it will discourage ppl from dirt dropping
looking good simon, hopefully be up on the weekend to watch you. If you pick up a sponser you reckon you will keep the car?
Also, do all type have a trade plate? Keen to take the 31 down to them one day to have a look at my holey, slightly rusted rear 1/4 and see wat they can do.
depends on the level of sponsorship man. if its an all out sponsor then we'd prob import a fully set up track car from japan. burt if its a medium level i'll keep my car and develop it some more.
yeah all type have a trader, and a car trailer... call them and discuss your needs man
Wow that had to suck! Just like me getting a new turbo fitted to my car and three days later having some old bag run a red light in a Kingswood and write off my car! :wub:
And DON'T say "Not the Kingswood"!!!! ;)
pickle me grandmother!!!
thanks guys... thats 4th gear btw... its got decent power to smoke the bags at 4th at that kind of speed (150 ish kph)
mate, i would have trouble getting up the balls to enter those corners doing 100 ks in a strait line! let alone going 150, sideways!
its a real mans sport, thats why i dont do it lol, id rather go fast in a strait line ha ha.
haha yeah the weird thing is i feel safer drifting at high speed then i do sitting at 160 on the highway/drag strip thats sore sure... no idea how to explain that.
update on car: pretty much all finished! just gotta primer it for the weekend (wont be painted sadly)
So your car wont be at all type on saturday? Was hoping to have a look at it up close.
Try turn 4 at 230pkh on a race bike, knee on the deck, topping out 5th, and knowing if you lose it at that turn, you're going to hospital ... no doubts about that!
Then hard on the brakes to shave off more than double your speed for the northern hairpin.
:P
God, I miss my race bike :D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
