  • Replies 71
Posted Images
Haha ... my balls are bigger than most. :starwars:
I get my bike sliding around that track. Into turn 3 (sometimes back wheel in the air) and out of turn 3 (avoiding the different grade patch of bitumen); back wheel in the air into turn 5 and 7 also, and sliding exiting turn 5 and sometimes out of the esses. Pirelli Super Corsas are fab tyres with lots of control for slides ... Michelins suck!
I can get my GSXR bitch shaking her ass :laughing-smiley-014:
I think your e-penis is bigger than most dude.
Saw the vids Simon, nasty hit, bloody tires...any chance we can speak to Clem to take the tires off, for future events? I really dont want to end up hitting those tires next time I am up there!
Better yet, he should actually concrete that bit there, if he is too wooried about the grass being destroyed.
I will see you this weekend eh?
Cheers
Ric
drifters meeting has just started tonight, so hopefully they will be able to come to some sort af agreement out of it about the tyres. Richo, when will we be seeing you out again and how is the car coming along? Pm if you want.
Jarrad that come up nice as man, only downside is know i wont know its you when i see you, the dent and scuff mark always gave it away lol.
TO plug these guys some more, checked out simons repair job closeup at mallala today and WOW! Can't believe how it looke now compared to 1 week ago. Its perfect! Paint and all. Will definately be running my car down to them sometime soon to see about some panel work.
Thanks Luke, yes its gone, still look at it and go, geez they did a good job haha. And yes, Simons car came up really good, not a mark on it.
Picked up my car on Saturday after having the rear bar repaired and the front bar and side skirts touched up and im stoked with their work. These guys do quality work and are a good bunch too, they matched the paint up perfectly and even washed my car when it was finished. Highly recommend All Type Crash to anyone looking at doing some bodywork on their car :D
A1
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
