Originally posted by ScarifieR
dude
im not an idiot
your tryin to basically steal this deck off him
i know he can get much more and u do too thats why your pissed
i bought some gear off poop so im doin the right thing
"dude", if you aren't interested in buying something,don't post. Don't be a pain in the arse for everyone else.
No offence intended.
cheers,
floody
Guys, seriously, enough of this crap!
The seller sets the price, he also has the right to change that price to WHATEVER he sees fit, if your not interested in buying it then don't bother replying, or if you think the price is too unreasonable, then you may wish to PM him, if you are looking at buying things that you think are a little on the high side, again, make an offer through PM's!
This sort of crap (people calling people idiots etc..) shouldn't be here.. please guys do the right thing!
and deano, if you don't have anything to say, stay out of it :)
yeah well flood
i dont give shit
i got a nice message saying thanks cause he did want more and now he knows of caraudioaustralia.com hes gonna sell all his stereo gear and get what he wants for it
i just hate freeloaders sayin ooh give ya 100 bucks for something thats worth 500
its called dreaming
and your a dreamer
so get a real skyline if u can AFFORD it
dude, if u still have the double din head...hmm its ages tho ay..
willing to take it off u for 300...if uve gotten more, its kewl..=)
just had this much and thought id give it a go
heh
l8rz
to be honest, it didn't go well at all. it most probably got damaged in the postal system (although i packed it up really, really good with heaps of bubble wrap) and the cd is skipping. getting it sent back to me with a full refund. but it's cool, i'm not the kind of person that would sell something dodgy anyway.
probably hook it up to my cd changer and use the deck as an equalizer...plus it does look quite flash :)
maybe yr buyer could get it checked out by an audio store as it could be something real simple?
have had dirty heads in my alpine deck bfore and cd skips erratically...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
