hello,
just wondering if anyone new a reasonably priced injectors seller.....
i thought about ordering through nengun or greenline....but i kinda need the injectors ASAP....
The last place i went to quoted $180 each for denso 444c and was told by a forum member that
this price was expensivve.
Unless this is the typical price i will be paying without ordering direct from japan
https://www.sau.com.au/forums/topic/218996-where-to-get-new-injectors/
hello,
which ones do you need and how many?
hello,
Have you try Perfectrun? They can be real quick if they have stock and consider 6 injectors weight nothing, EMS will only take maximum 2days. Is it leaking?
yeah there leaking
i'm actually even scared to buy new ones because ive been through 2 sets of used ones but they keep leaking in diferent points everytime..........like point 1 and 3 then change then leak in 2 and 4 then change and change seals too then they leak in 2 and 5 ????????????????????
Sliding performance was selling Nismo's cheaper than Nengun last time I checked.
I was gonna suggest slide also.
You could also look for 2nd hand jobbies, but factor in the cost of a clean and flow test if you go down that route.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
